cup holders in first gen 4runner and second gen trucks
Old 10-16-2012, 01:30 PM
Crapple21's Avatar
So awhile back I read on one of the forums about someone putting a vw passat or jetta cupholder into our trucks. So after looking for awhile I finally found one out of a passat and installed it into my 4runner and it works great. So i thought id share with you my solution to the cupholder problem everybody seems to have with our trucks. This set up cost me under 20 bucks.
So here is what you need.
First you need to find a cupholder at a junkyard or online. I would recommend a junkyard way cheaper then online
Next you will need to buy some 3m double sided tape
Then you will need to make some type of support or find something that will work. I used a plastic piece of a 4runners roll bar and that works perfect. I had an extra one in my garage.
Then you will need to attach the double sided tape to the top of the cupholder, to the inside part of the plastic piece so it stays in place and to the top of the support as well
Then you carefully slide the cup holder in place so its flush on both sides of the radio bezel thing. And then you have cupholders that almost look like factory and work great
if you have any questions let me know
Old 10-16-2012, 01:46 PM
runs-on-4's Avatar
does it go into 5th with out hitting?
Old 10-16-2012, 01:50 PM
Crapple21's Avatar
yup i drove it on the freeway right after i installed it.
Old 10-16-2012, 01:54 PM
JBurt's Avatar
Do you know what years/models vw's have that type of cup holder?
Old 10-16-2012, 02:00 PM
Crapple21's Avatar
i think its 2000 and newer passat or jetta I got mine out of a passat
here s a picture of my truck in 5th with the cup holder out
Old 10-16-2012, 06:16 PM
ToyoTech559's Avatar
sweet thanks. got to see if this will work for my automatic. only problem i see is.. for the driver its a reach for the drink tho
Old 10-16-2012, 09:30 PM
Crapple21's Avatar
It's actually not bad at all to reach your drink
Old 10-16-2012, 11:26 PM
wyoming9's Avatar
Red face
Just curious where you live??
Around here the first good pothole i think it would just break right off.If it didn`t break have enough spring action to bounce the cup out.
Then with my short arms It would be quite a stretch to reach the cup.
Old 10-17-2012, 12:27 AM
Crapple21's Avatar
That's what the support thing is for so it doesn't come off and the cup holder has like rubber things to hold the cup trust me it work great and isn't that far of a reach
Old 11-25-2012, 03:43 PM
rattlewagon's Avatar
This is great! Im of to the junkyard this week to look for one!
Old 02-14-2015, 09:27 AM
Crapple21's Avatar
A quick update On this it's still working great haven't spilled a drink yet. I changed how I mounted it I used a metal strap and ran it underneath and used the pre existing screw holes on the side of the radio area and it's holding up great.
Old 02-14-2015, 10:09 AM
BigBluePile's Avatar
Damn, that's sweet! Too bad that will cover up my cb speaker :/
Old 02-14-2015, 02:25 PM
Crapple21's Avatar
Ya I had that problem too but I ended up moving my cb under my passenger seat. I figured i use my cup holders almost everyday and I only use my cb every once and awhile
Old 02-14-2015, 04:08 PM
Hmmmmm...good point
Old 02-25-2015, 03:25 PM
Just ordered one off eBay. Yay me
Old 03-12-2015, 11:37 PM
maco35's Avatar
Old 03-18-2015, 08:43 PM
So, today I mounted my new VW cup holders:
Old 03-19-2015, 06:43 PM
maco35's Avatar
How did you secure yours? ^^ ^^
Old 03-19-2015, 06:58 PM
bootscootboogie's Avatar
I was thinking about trying to rig up something in place of my ashtray but man... This is really snazzy
Old 03-19-2015, 07:41 PM
Magic.
With the help of some aluminum stock I'm not completely done yet though. Still have to clean up the metal.
Quick Reply: cup holders in first gen 4runner and second gen trucks
