where the heck is my trans fill plug?
Old 03-19-2011, 03:21 PM
skoti89's Avatar
I see the drain plug on the bottom of the transmission, but where is the fill plug at?
It is a 87 4runner 22re 5 speed. w56? im not sure of the model
Old 03-19-2011, 03:42 PM
4Crawler's Avatar
Usually driver's side, next to the reverse light switch. Which is the switch? The only thing on the side of the trans. with wires hooked to it.
Red = fill
Green = drain
Blue = reverse
Old 03-19-2011, 04:01 PM
skoti89's Avatar
awesome, found it. I was looking for another big ol 24 mm bolt.
what about the tcase?
Old 03-19-2011, 04:11 PM
4Crawler's Avatar
Back of the t-case:
I have the Front Range t-case x=member, but the big hole in it is for the fill plug, just below and to the right of the speedo cable.
Old 03-19-2011, 04:22 PM
skoti89's Avatar
hey thanks alot for you help..the t case oil came out white....not joke
vanilla milkshake status.
Old 03-19-2011, 04:41 PM
metalhed's Avatar
sucked in some water, probably thru the Vent
I would fill, drive around slowly in 4 wheel drive and drain, refill and call it good
Old 03-19-2011, 05:15 PM
4Crawler's Avatar
Typically no separate vent on the earlier t-cases, they vent through the shifter base. If the boots are torn up, especially the inner most one that covers the base of the shifter, water kicked up from the road can get in from above. Happened to a buddy's rear case.
Old 04-21-2024, 06:41 PM
O’Quinn1210's Avatar
Side note on t-case.
[QUOTE=skoti89;51684892]awesome, found it. I was looking for another big ol 24 mm bolt.
what about the tcase?[
wykp
03-17-2021 01:51 PM
Parasitick
08-01-2014 09:29 PM
chaz1951
08-11-2011 02:06 PM
Tacoma750
10-17-2008 02:58 PM
MMA_Alex
12-24-2006 03:19 PM
Quick Reply: where the heck is my trans fill plug?
