stuck gas pedal
Old 04-22-2012, 07:25 PM
conquistador's Avatar
stuck gas pedal
I recently purchased a first gen 4runner w/ EFI 22RE. I am having a problem with a hard gas pedal upon start up. The first time I hit the gas after starting the engine the pedal is stiff and difficult to press. Once it is pressed it goes back to normal. I sprayed silicon spray on throttle cable and linkage but that doesn't seem to be the problem. Any ideas on how to remedy this is appreciated.
Old 04-22-2012, 07:40 PM
Discombobulated's Avatar
Might just start at the pedal work to the end, something kinked modified does your throttle on the body move smooth?
Old 04-22-2012, 07:45 PM
slick3419's Avatar
I have the same issue but with a 3.0, real stiff upon start up but once its depressed everythings fine its wierd. I havent loked into it yet but when I do I post what I find for you.
Old 04-22-2012, 07:52 PM
Throttle body action seems smooth
Old 04-22-2012, 09:08 PM
Inferno451's Avatar
I'd bet the butterfly in the throttle is getting stuck every once in a while. Back the throttle stop screw out, then close the throttle, then screw in the stop screw until you can see it opening the butterfly, then keep screwing it in 1/4 or 1/2 a turn. Same thing happened to me.
Old 04-22-2012, 09:13 PM
wyoming9's Avatar
Red face
Might just be time for a new cable they do go bad being this old sometimes.
Old 06-13-2012, 04:18 PM
slick3419's Avatar
I took off the throttle body and cleaned it inside and out with carb cleaner and it seemed to have fixed it for me.
Old 06-13-2012, 09:50 PM
Thanks for the update. I think this will be my weekend project.
smthwsn357
05-01-2024 07:28 AM
HollieJayyy
08-09-2015 07:59 AM
D.B.T. 87 4x4
07-20-2015 04:51 PM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: stuck gas pedal
