pic of 85 efi motor top and big yellow screw vacuum port?
Hello all
First question
Does anyone have a good pic of the top of there early 85 efi motor, the po left everything amess and i want too bolt everything down back orig aka vacuum lines and such
Second
The big white or yellow screw right next too the E and F on the top of the motor has a vacuum port on the bottom (where does that go too)? Mine is open but truck runs and I want too go in for smog check CA. So have too button up.
Third
My 3 in ish front lift seems too be rancho and its very stiff
what do you think about removing a leave and adding a longer front shackle(cheap easy, could make it flex and have same lift too match rear 63 chevies)???
Thanks
First question
Second
Third
Thanks
Thank you ,Thank you can you answer the second question the pics are great not the top one but the lower lower one thanks
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
