how to adjust a holley fuel regulator
Old 01-22-2012, 08:01 AM
creswellhick's Avatar
so heres another stupid ? i went to put my reg and gauge on yesterday got all together and i couldnt figure how to adjust the reg i know there preset to 2.7 but i want to adjust it for my truck. theres a place for an allen wrench on top that looked to be wat to adjust with but wouldnt budge. i would use my instructions but they got wet ... thanks guys
Old 01-22-2012, 08:49 AM
xxxtreme22r's Avatar
You have to loosen the locknut around it. And if I remember right, turn the allen screw counter clockwise to lower, clockwise to raise. If turning clockwise, be sure to loosen the locknut enough to allow the allen screw to thread itself in. When tightening the locknut back up, hold allen screw with wrench, otherwise it will change pressure some.
Old 01-22-2012, 09:06 AM
ok ill look into it think u can post a pic of your setup under the hood
You don't wanna know. lol
Old 01-22-2012, 09:09 AM
i do cause mine looked like crap when it was hooked up.... does it matter how much fuel line i use so i can mount it to the wheel well or fire wall
Old 01-22-2012, 09:11 AM
lol, mine's probably worse, trust me. Doesn't matter how much hose you use. But do yourself a favor and use EFI hoses and clamps. Keep the bends to minimal and watch for kinking and moving parts. Make sure you have a little slack as well to compensate for engine movement.
Old 01-22-2012, 09:13 AM
ok sounds good. didnt think wat hose i used matterd. is there a big difference of hose? and i just used hose clamps lol for the moment.
Old 01-22-2012, 09:17 AM
Just extra insurance. EFI hose clamps put even pressure around the fittings and EFI hose is reinforced with string fibers. Just overall stronger.
Old 01-22-2012, 09:20 AM
the crap i got from napa had string on the insid when i was cuttin it but really lets see a pic
Doug4320
03-24-2018 10:11 PM
80Truck
07-24-2015 03:12 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: how to adjust a holley fuel regulator
