Hard to start when cold. Loss of power.
So when the weather turned cold, my truck started running like CRAP. It's a 1984 22r with a EFI conversion(CA). When cold it takes a little while to start and when it does it sputters in the low rpms. Then when i try and rev it it bogs and can die if I give it too much gas. When it warms up it run ok. Only OK. I ran it to my friends house about 30 miles away and it threw a code 5, not to mention it ran like ˟˟˟˟ the whole time. When warm it idles fine and starts up fine. Here are some things I did.
Replaced spark plugs/Wires.
Checked Ignition coil
Replaced Igniter
Checked AFM
Replaced fuel filter
Ran seafoam in vacuum line and tank
I'm thinking clogged injector(s) or valve clearance off. The code 5 I got says bad o2 bad ECU or injectors running full rich/lean. I think it's running full lean seeing as I changed the plugs and they looked pretty burnt. I need help fixing this BADLY it's driving me nuts....
Thanks!
Replaced Igniter
Checked AFM
Thanks!
Valves all in spec. And I found that my truck is equipped with a LCE adjustable cam gear. Don't know what it does other than advancing the timing?
So I guess the valves weren't my problem. I tested the AFM and it is in spec. But I still think thats the problem....
Hard start how? Like it cranks and cranks and cranks? Then stumbles and then cranks and cranks? Then fires off finally?
https://www.yotatech.com/forums/f128...-22r-e-228223/
Thanks for the reply. I will see what adjusting it does. Would this also make it run lean when it's warmed up? On the way home I was cruising at 55mph and the CEL came on ending up to be a code 5. It feels like it wasn't getting enough gas causing it to throw that lean code...
Ok I adjusted it. It seemed like it was only half the problem. It started, but when I rev it it bogs down. It seems like it's starving for fuel, or getting too much air... This is so frustrating, i've never had such a troublesome 22re.. I'm about to set it on fire.
Ok This thing was modified a bunch by the Previous Owner. It looks to have an in-line fuel pump AND a backup napa fuel pump. I think the fuel pump is going out. I'm gonna try and hook up the napa pump and see what happens.
Unfortunately with these early efi's is it can be pretty difficult to figure out what's wrong. It's not like obd2 vehicles. I was always really lucky with mine and never had an issue. It still sounds like an afm issue to me. You fully checked the afm against the fsm specs right? The cold start injector should help when motor is cold and I believe that's controlled off one of the temp sensors under the throttle body. Not sure about the o2 sensor since I never had issues but I did make sure to use OEM ones, the denso units iirc
It shouldnt no, afaik. Only kicks on in a cold start condition.
You could have a bad connection somewhere. You may have to read everything out from the ecu out to the sensors. Theres a lot of info on here about troubleshooting these issues. Now this is a swapped in efi? Did you take everything from the donor? These 22re efi systems were used for many years and mix matching usually leads to issues.
Yes it has wayyy good spark. It has a MSD ignition 6A with the stock toyota coil. I replaced the coil and it did nothing to help the problem so I took the replacement part back...
I could tell that the truck wasnt as powerful as it could be when I got it, and the problem just got worse. Only recently has it given me such bad issues like not starting at all. It's weird, because it seems intermittent. I thought it was the AFM in the beginning, and that might be what it is gonna end up being. There are a bunch of flat spots through the rpm range...
Hmmmm....an aftermarket ignition system. I had an crane hi6 ignition box on mine and the truck ran worse. I kept the crane coil and put the OEM ignition back on. Ran way better.
Also, the ecu "should" be under the passenger kick panel.
Alrighty. I just checked the AFM again.... I'm not getting a reading in a few of the terminals that are supposed to be a certain ohm. BASTARD afm! lol... I thought it was the culprit the whole time. Looks like i'm gonna have to shell out some bucks to truly find out if it was the problem...
Any suggestions on where to purchase one? Used? Ebay? I heard of the supra being some sort of upgrade? Should I just replace it with the same unit?
Thanks!
Thanks!
I will try and post an update when I get an AFM.
