hard brake pedal no stopping power please help?
Sorry if this has already been answered but could not seem to find it when searched i got a 93 yota dlx v6 4x4 i have replaced multiple lines new master cylinder wheel cylinders caliper rotors drums shoes almost everything. i got a hard pedal but no stopping power i have vaccum to the booster everything bleeds fine just cant seem to get good brakes any help would be great thanks
Unless there is a line blockage (unlikely) you should have vacuum at the booster, that doesn't necessarily mean its working properly.
You say you have vacuum at the booster, I assume this means engine vacuum. Have you checked your vacuum booster for a leak? Hand vacuum pump is all you need to test.
ok is there a certain way to test it? yes the backs are adjusted and i did grease the self adjuster how do i do that vaccum test i did the pump break start and it goes down i pulled the hose of and hear the booster relieve air any other test would be great?
Are you sure the lines are completely bled? You can buy a one man bleeder that also has a vacuum tester. I payed around $50 I believe at oreiley auto. I assume you have new fluid? If the fluid is dark or rusty brown looking it can compress without actuating the piston/cylinder. Also is the pedal stiff in a normal way or in a binding way? Also make sure you have no lube on the pads.
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
skoti89
07-08-2015 12:05 AM
