Domed Pistons ver. Flat Top Pistons
Old 09-16-2010, 05:28 PM
bob nob's Avatar
Question Domed Pistons ver. Flat Top Pistons
Can a 22r TEQ head that normally has domed pistons be used on a 22r block with flat top pistons instead? Will there be a great compression ratio lost?
Old 09-16-2010, 05:51 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Welcome.
Originally Posted by tried4x2signN
79-84 And 85-95 will not interchange.
The block deck was de-decked in 85. So you cannot and should not interchange the heads.
85-95... Blocks are all the same (Ex Turbo) Semi-flat topped pistons. Have a slight dish.
79-84 blocks are easily ID'd by the high top pistons.
Here's a RE cover on an early 22R block
Old 03-05-2019, 04:44 PM
rsmdon's Avatar
Wrong thread
bigjstang
08-25-2021 12:41 AM
theking11863
03-19-2016 09:36 PM
mr_manny
07-31-2015 10:39 AM
TDonkey
07-26-2015 10:14 AM
msane99
07-11-2015 08:08 PM
Quick Reply: Domed Pistons ver. Flat Top Pistons
