Cant find detailed EGR removal guide.
Old 10-19-2010, 12:15 AM
IngSoc's Avatar
I have serched for about an hour now and have come across this same question but no answers. Plenty of oppions and alot of good reading but still yet no good play by play guides to removeing the EGR in a 22re. I know it is supper basic but is there any one that can point me in the right direction please.
Old 10-19-2010, 08:20 AM
irab88's Avatar
do you have a pic of your engine? that would help a bit.
basically, take everything off egr-related up to the block. then make some covers out of a soda can and use the egr plates and bolts to hold them in place.
Old 10-19-2010, 12:36 PM
874runnersr5's Avatar
[IMG][/IMG]
here are block off plates i made..
Old 10-19-2010, 12:45 PM
blake.nemitz's Avatar
i puilled the egr tube outta my intake and welded the holes shut and put it all back tigether, looks factory with no mods except now it simply doesnt work
Old 10-19-2010, 02:55 PM
IngSoc's Avatar
Where is the triangle blockoff go? Any pictures with highlights to every thing remove... really soda can will work? Know it must be supper simple just turning still that's all
Old 10-19-2010, 04:38 PM
the triangle plate goes on the side of the head where the egr was removed from.
Old 10-19-2010, 08:36 PM
irab88's Avatar
yeah. i've seen it done somewhere else (i forget where or who). looks nice if you have a clean block and shiny can
Old 10-19-2010, 11:43 PM
myyota's Avatar
LC Engineering make a block off kit for removing the EGR. Its easy to do, just remove the EGR and install the block off plates in it place and plug the vacuum line.
Old 10-20-2010, 05:20 AM
irab88's Avatar
here's some pics of the lc engineering kit installed
Old 10-20-2010, 11:08 AM
maistroyoda's Avatar
I traced the egr outline onto a steel electrical cover plate then cut it out with an angle grinder. After that just used the original bolts to screw it on to the head. Assuming that you're using an after market carb, then just remove most of the vacuum lines and plug the outlets
Old 10-20-2010, 11:13 AM
xxxtreme22r's Avatar
dude that electrical cover idea is great, never though of that. gonna have to keep that in mind when I decide to finally clean up my hack of a weber install. lol.
jerusry
10-19-2015 05:28 PM
msane99
07-17-2015 10:13 AM
87blyota
07-10-2015 04:31 AM
Snort
07-09-2015 03:58 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Cant find detailed EGR removal guide.
