Built 22RE:How much power can I expect?
Old 01-17-2011, 05:08 PM
Sleepr71's Avatar
Trying to plan out how I want to replace the tired 22RE in my 85 4x4 5-spd.It's smoking a little,sounds like the timing chain needs replacing(?may just be valves need adjusting,idk). I am seriously thinking of just re-building the 22RE...Re-built shortblock, home ported head,tri-y header,small(260-268) rv cam, and free-flowing 2.25 '' exhaust(already have). I also already have a "re-built" head(stock valves/springs) for a 22RE,like the reliability & fuel mileage of the 22RE, and absolutely want to keep the A/C,thus eliminating "most" swaps like a 7mge. What kind of realistic power& seat of the pants difference have you noticed? If it helps..my truck has the stock 4.1 gears,5-spd, and I seriously doubt that I'll ever run bigger than a 32x11.50 tire on this one(DD/long distance, all purpose hunting rig). Thanks,Sleepr71.
Old 01-17-2011, 05:14 PM
waskillywabbit's Avatar
You go from 2 squirrels to 4 squirrel wapow.
:wabbit2:
Old 01-17-2011, 05:41 PM
Sleepr71's Avatar
:wabbit2:
Wow..I didn't realize that so few mods. would DOUBLE my S.P. #'s. No wonder everybody wants to keep their 22RE! Seriously..I was hoping for 20-25 HORSE power/ft. lbs torque gain. Pipe dream I guess on a 22RE? Sleepr71
Old 01-17-2011, 06:14 PM
xxxtreme22r's Avatar
which motor do you have in that truck tall deck or short deck, I think some of those 85's had either or. did the tall decks even come EFI, newb question I guess I should already know that. lol.
Old 01-17-2011, 07:35 PM
merfal's Avatar
I did a EB 261 cam a rebuilt head with oversized valves and a full LCE exhaust when I rebuilt mine...I wish I had kept the money and done something else
Old 01-18-2011, 01:34 AM
Enprize's Avatar
I'll let you know in a few days. I'm currently having a 22re engine built in Denver with an rv cm and headers so I can continue on to Ft Knox from Seattle dragging a 5x8 utility trailer with a BMW 1150 GS loaded on it. Decided to have it done there after pulling Elk mountain in second gear. the shop said I should get an additional ~30 hp with the mods. With 260,000 miles on the stock motor the crank was scored and the loss of power was due to flattened cam.
Old 01-18-2011, 05:47 PM
Sleepr71's Avatar
Thanks for the opinions/experiences so far! I guess,sometimes the truth hurts. I'd prefer to make the right choice on powerplant the FIRST time around & spend $$$ on worthwile mods... Enprize, hopefully you can give some real world feedback after you break-in your rebuilt 22RE. Sleepr71.
Old 01-18-2011, 06:16 PM
peow130's Avatar
better off just swapping a chevy 4.3, or a toyota 3.4..
Old 01-18-2011, 06:28 PM
sebastianholmes's Avatar
because thats so simple and cost-friendly...
Old 01-18-2011, 07:06 PM
Greg_Canada's Avatar
Ummm... 89+ intake, supra AFM, header, exhaust, head, cam, 130-140 crank hp.
add some higher compression pistons... and you can get more, just will need to run premium.
Want more power? a good tune, with a SMT-7, or standalone like an SDS or megasquirt...
Old 01-18-2011, 07:34 PM
olharleyman's Avatar
I can say I have about 140-145 hp after a full rebuild everything new but connecting rods but they were shot peened and with my 35 x 12.5's I can roll about 80-85 till a hill then it falls off. I have a L.C.E. Pro street head ( if I did it again I would go with the engnbldr head same set up as L.C.E. half the price ) engnbldr 268 cam .20 over piston rings tri y header 2.25 to cat and 2.5 out with a flowmaster 40 5.29 rears 5 speed.
If I could have done it at the time (and I will do it some time soon) I would just do the 3.4 swap for just about the same cost as my complete rebuild , don't get me wrong I am very happy with my 22re but it is a work out to keep it rolling with the traffic at 75-85mph and there is not much more I can do to get any more out of her , but it is what it is and I am happy just not satisfied if ya know what I mean.
Old 01-18-2011, 08:36 PM
MudHippy's Avatar
Save your money, get real squirrels instead. Then you'll know exactly how many you've got working for ya under the hood!
Old 01-19-2011, 05:35 PM
Sleepr71's Avatar
Lol..the negativity. So,it sounds like there are gains to be had w/ the right parts combo..but yur just not going to make a 4 cyl push a ~4,000lb. 4x4 truck like a v6 or v8 will. I have seen a pro-built 22RE w/ aftermarket efi/turbo setup on a 2wd & it HAULS @$$! I'm guessing ~250-300hp as it runs low 8's through the 1/8 mile!
What is the main weakness on the 22R/RE's(from a power building standpoint)..poor head/port design & flow #'s? Poor flowing intakes/throttle bodies?The bore/stroke #'s look o.k. to me(almost square). I've seen 2.3 Fords make good power,yet remain torquey & very streetable(on 89 oct. gas).Sleepr71.
Old 01-19-2011, 06:15 PM
peow130's Avatar
The main cons?
Well, heres the way you should look at things
The 22R is an engine with a stock output of roughly 100HP...
However, the 22R is capable of going through hell and back..
Now, it's not a powerful engine by any means and was never designed to be..
If you want a really fast truck or car, go buy a honda and rice it out.
If you want a cheap and fast car, go buy any car from the 70's with an SBC350 and build a 383 for under 2500..
but you'll never see the gains that those engines make from a 22r, without spending an extreme amount of money..
You can, however, make the 22R have a different delivery of it's available power through cams, and timing.
You can even go as far as to put a 20R head on a 22R block (not 22RE), and build the 20R head to have even larger flowing valves, a cam, etc etc. But you're not looking at a 300 HP engine..
Old 01-19-2011, 06:33 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Originally Posted by peow130
The main cons?
Finally! Some common sense!
I wonder why they don't make foot-long Swiss Army knives?
Is it b/c there is no use for one? Or it'll be useless as a survival tool at that size?
I don't know?
Now the 22R... A "Survival knife" of a motor.. Not really a new motor, with new electronics that can be manipulated, or things like "Twin Cam" or, Variable Valve timing...
It just goes. Cave-man simple...
So, why would somebody want a foot-long Swiss Army knife, or a "more powerful" 22R again?
...find another engine.
Search a 7MG, 3Rz, 4.3 or a 5Vz swap.
PS, if anyone knows where I can find a foot-long Swiss Army knife, let me know...
Old 01-19-2011, 07:30 PM
holy negativity, the OP says he wants maybe 20-25 horse power, from what i read i would say he can do what he planned on for about $1200 probably less, and its pretty straightforward and easy. an engine costs at least $2000 and is alot more complicated and difficult. he never said he wants a 300 horsepower engine. all he wants is...
Seriously..I was hoping for 20-25 HORSE power/ft. lbs torque gain. Sleepr71
seems easily doable to me
Old 01-22-2011, 09:09 AM
benelli's Avatar
Wow, this sure ain't my chevy.
I just rebuilt my 22r and should be dropping it in next weekend, I'll let you know how the power is. I can't compare to a stock engine because it didn't ran when I got it. I wonder how it'll feel vs my 400HP K10, but I got it for gas mileage - not to haul ass.
Old 09-13-2013, 11:17 PM
NARFALICIOUS's Avatar
Possibility /what's needed for 205 Crank HP ?
Cam (which one, what profile ?)
Ported head
Ported intake
Supra MAF
Header
Exhaust
Higher compression (10.1, 10.5, 11.0, higher?)
Tuned
What else?
Old 09-14-2013, 01:51 AM
wyoming9's Avatar
Red face
You forgot bigger valves and perhaps bigger injectors depending on the cam.
Then I doubt you can get that horse power without forced induction
Till your done you will have about $ 4000 to 5000 in the engine
A stock 3.4 puts out more Horse power !!
Liadrin
04-25-2022 02:54 PM
Team420
12-30-2015 01:31 PM
Liadrin
09-01-2015 06:44 AM
priest16
15
08-06-2015 07:43 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: Built 22RE:How much power can I expect?
