brake problems after rear disc conversion and MC upgrade
I just recently did the rear disc brake conversion. I went with a new 1" bore MC, bled all the brakes with no air in the lines. But i still have to pump the brakes when im wheeling to get it to stop. A buddy of mine said the booster could be bad? Shoot me some ideas.........
Is the MC you used for 4wheel disk brakes? Did you bench bleed the MC before you installed it? Do you have an adjustable pressure valve for the rear circuit? Some more info might help and keep in mind that any mod to the system will change how everything works, like different calipers in front and adding to the rear and changing the master cylinder.
you bled RR, LF, RF, LF? in that order furthest to closest?
what proportioning valve did you use in the back?
some say you are fine with the LSPV (did you bleed that if you still have it?)
personally I am going to be using the kit from Front Range:
it will be mounted on the MC
kits like the one from Dave's off road are mounted back in place of the LSPV"
Did you bench bleed the MC prior to installing it?
Usually from my experience, if the booster is bad then you get a very stiff pedal. If you try all that was stated above, I have found with brake swaps that sometimes it seems as though all the air is out but still feels squishy, gravity bleeding each caliper for a bit has always helped me with this issue.
No brakes...need help
I just put all new brakes master cylinder rear disc brakes and rotors. Bled lines with no air. Still have to pump brakes to have to stop. What the deal Idk. Im stuck. Any suggestions?
there a pita to bleed the brakes, after doing my master and a caliper i was able to get my brakes by doing them in order that fsm calls for and with the truck running and used a one man bleeder kit... did 3 pumps on each one and ended up with a nice brake pedal
If you don't bench bleed the master you can still have air no matter how many quarts you run through it. Also if the reservoir goes dry after you bench bleed it or while bleeding the system, you will have to start over.
After you have properly bled the system and still have issues, you will need to check the gap between the booster push rod and the cylinder. You will need a special guage that looks like an H with a rod in the center that is a guage to measure the depth of the rod sticking out of the booster then you turn it around and measure the depth of contact in the cylinder. If there is too much gap or the rod slightly pushes in on the cylinder with no pedal pressure you will have break problems. You should do this before it goes in the car and bled, however it can be done now it is just a PITA.
Gravel Maker
RuffStuff
07-06-2015 07:43 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
FS[PacSouthWest]: Want To Sell: 1988 Pickup In LA county California
Peach
07-03-2015 09:30 AM
