Best Repair Manual (22RE Pickup)
Best Repair Manual? (22RE Pickup)
HELLLLOOOOOOOOO!
So this will be my first post on Yotatech as I have just purchased my first Yota! As of yesterday, my daily,
crosscountry, work and everything else driver is a 5 speed '91 toyota pickup (22re). My last vehicle
(1988 4sp VW Vanagon) was dilapidated, not well maintained and caused headache after headache. Now that
I have this pristine pickup at only 60k miles I am determined to maintain and repair as necessary.
I've done some searching and have found mixed reviews about the quality of service manuals. So I
thought it may be helpful (especially for newbies like myself) to open a thread to discuss the best service manuals.
Obviously, it seems that the Factory Service Manuals (FSM) will be the most specific, and probably the most helpful,
to each specific vehicle. However, my last day of searching for it has lead me to believe that these are not only
expensive but very difficult to find. I've also been reading many posts about the Haynes Manuals but seem to be
hearing mixed reviews.
I've seen many links for supposed free online PDF file and other downloadable manuals posted on various threads,
but none seem to still be functioning.
Does anyone have an updated version of a downloadable manual?
Are there any other manuals aside from the two stated above that are worth mentioning for a DIY car guy?
Does the Haynes Manual do the job?
Is the FSM worth the dough?
Thanks for any responses, and I hope this thread was used correctly.
-Scott
-Scott
Heres the link to the 93 Toyota FSMhttp://personal.utulsa.edu/~nathan-buchanan/93fsm/. I would download it and save or print some out (its really long). Other than that, a simple Haynes manual does a decent job for covering the basics and YotaTech is a great resource as well. Lastly, 4crawler.com has some great info
You should at least try and get a copy of the EWD`s(Electrical wiring Diagrams) for your year truck.
It seems no matter what manual you get there is always something you can`t figure out.
Yes I think the Hard copies of the Factory service Manuals are very worth it if your getting into hardcore wrenching.
Changing the oil greasing not so much.
Thanks for the replies guys. Just ordered a Haynes Manual that should be in tomorrow.
And thanks a lot highonpottery for online version, the link actually worked!
Anything electrical has always scared me away and I never have learned to read a wiring diagram... Though I just stumbled across a multimeter for ten bucks at a pawn shop so I guess that's my cue to start doing some research.
wyoming9 You should at least try and get a copy of the EWD`s(Electrical wiring Diagrams) for your year truck.
vpower1989
Personal Sales Rating: (0)
yotatech. Just did my timing chain, guides, tensioner, cover, water pump, oil pump all from searching forums on this site. I did reference the FSM for torque specs though.
But I'll help you search go copy this in to google
22re rebuild or replace on yotatech.com
You will get tons of results from people that had to make the same choice as you. Good luck hope this help
Jnkml
07-06-2015 01:20 PM
