BAD hesitation/ power loss/ gas mileage - no check engine light/codes
#61
Unfortunately, I found the correction to the problem. While being lazy, I used a spray to clean the intake valves since cylinder 4 was not firing. I subsequently, seized the block as I could not maintain enough engine speed to keep sufficient oil flow enough to balance engine stutter; THE ENGINE IS NOW SEIZED at cylinder 1 on the crankshaft.
Upon removing the rocker arm assembly and camshaft, I noticed the camshaft was worn so badly, each lobe had a 1/2 inch blade from wear from the rocker arms. The engine should not have been running at all.
Justin's Fly
42
02-10-2023 05:02 PM
kaiowa99
03-29-2011 04:33 AM
MB4runner
50
02-16-2011 07:00 AM
berlybelle
09-02-2003 05:20 AM
