5vzfe timing belt help
Old 06-23-2013, 10:45 AM
snyderiii's Avatar
Originally Posted by DeathCougar
5VZFE is a Non-interference motor, so you can spin the crank and cams separate of each other for days. Just line up the match marks, and you are golden. Probably one of the easiest Toyota motors to do a timing belt on
First time doing this... everything disassembled after reading the many threads on here. Went to remove the right cam sprocket. I lost my grip on the pulley holding tool and the cam "popped" about two thirds of the way counter clockwise off the tdc mark. I about freaked out... still am actually. For good measure I cranked it back clockwise to see if I could get it to line back up and it sprung/popped about 180 degrees clockwise which meant it was not to the right of tdc about 15 or 20 degrees. This time (im a slow learner) I very carefully turned the pulley tool until the right cam (counter clockwise) until the sprocket was lined back up to tdc. Now what? Am I going to have timing issues forever? If I get those sprockets off (to check/replace cam seals) is there some kind of spring retensioning im going to have to deal with. Have both fsm and haynes and they dont mention this? Oooorrrrr, should I just stop because the random independent rotation of the right cam sprocket is going to have me hosed.
Thanks.
Old 06-23-2013, 10:48 AM
Staff
DeathCougar's Avatar
Just line up the marks, and you will be fine. The reason its "popping" is because the valve springs are trying to force the valve closed.
You shouldn't have any timing issues what so ever as long as your match marks are ok. The cam can spin either way without any issues.
Old 09-22-2014, 08:43 PM
herbsicecream's Avatar
Originally Posted by SacRunner
Yeah, that probably isn't good, chances are the belt was installed incorrectly (off by a tooth somewhere).
At this point, I would remove the belt then turn each pulley individually to get all the timing marks lined back up then install the new belt. If I remember correctly, the passenger cam will want to "spring forward" when the timing marks are lined up and can be a bit of a pain to work with.
As for clockwise vs. counter-clockwise, the FSM says to only turn the motor over in a clockwise direction, which I'm sure they state for a reason, but I have rotated my cam gears counter clockwise (in a very small amount, maybe 1/16 of a rotation?) and haven't seen any problems.
I have had this issue today. My passenger side cam springs forward when I try to get the new belt on. Is there a good way to get it on there while holding everyting in TDC? Struggled with it for an hour and cut up my hands good.
Old 09-23-2014, 02:57 AM
rworegon's Avatar
What I do is get the belt on the driver side cam and then use a soft jaw spring clamp to hold it in place. Then I use a breaker bar and socket on the passenger cam bolt to control the jump while placing the belt on the cam and one on, place a clamp on it.
Sometimes if the belt is fighting me, I'll use a ratchet/breaker bar on the driver side cam bolt and then turn it counter-clockwise to get a little slack while turning the driver side side very slight clockwise.....this works for me to get both belt on both cam TDC marks.
Old 09-26-2014, 06:01 PM
  #25
Brianm640's Avatar
Yeah, a breaker bar works best for me to control the valvebounce(as I call it). Ratchets tend to spring one way or the other, the breaker bar will hold it as long as you're holding it. If you got a buddy who will help hold it, that works too.
The biggest issue I had was trying to do this all while I had the tensioner still in. I realized its so much easier if I just reset the tensioner and put a pin in it than trying to fight it.
Old 12-11-2014, 05:48 AM
  #26
Trenklege's Avatar
Off an inch
I am replacing my water pump and I am at the point now where I need to take the timing belt off but the crank marks are off an inch when the cam marks are at tdc. What would cause this to happen, truck seems to be running fine. Also the crank bolt was very easy to loosen. I had the belt replaced 30000 miles ago and the water pump is leaking. What do I do? Should I align the cam marks before I pull the belt and rotate the crank aligning the marks when I put the new belt on?
The timing marks on the old belt will (just about) never line up with the timing marks on the cam and crank pulleys; this is expected.
Line up the timing marks on the cam pulleys with the paint dot on the rear timing belt cover, or line up the timing mark on the crank pulley with the mark on the oil pump; don't look at the marks on the belt, they're only there for proper alignment at install. If all 3 pulleys don't line up, rotate the crank a full rotation and check again.
When you install the new belt, make sure all timing marks line up and that the marks on the belt match the marks on the pulleys (assuming an OEM Toyota belt). With all the idler pulleys installed and the tensioner released, rotate the crank 2 times and verify that the timing marks on the pulleys match up with the reference points; the marks on the belt will be off a tooth or 2 (again, this is expected).
Old 12-11-2014, 06:48 AM
  #27
rworegon's Avatar
The 5vz-fe is a non-interference engine so you can rotate both cams and crank without issues when the belt is off.
Be sure to torque the crank bolt to 217 ft-lbs when reinstalling.
Old 12-11-2014, 09:19 AM
  #28
SacRunner's Avatar
I assume you're only looking at the marks stamped into the crank pulley and oil pump and the 2 cam pulleys and the rear timing cover, and not trying to align the marks on the belt.
Are you saying that when the marks on the 2 cams are at 12:00 (and lined up with the marks on the timing cover) that the mark on the crank pulley is an inch away from the mark on the oil pump? That would not be good, and yes, make sure all the marks are lined up correctly during re-assembly.
Even though the belt only has 30K on it, I would go buy a new TOYOTA timing belt (either from a dealer or one of the many Amazon/eBay sellers) for $60 or so, which will have all the correct marks on the belt which makes the re-assembly that much easier.
Old 12-11-2014, 09:36 PM
  #29
Yeah I ended up just throwing a set of gloves on and I grabbed it in a way where I could force it to TDC perfectly and then tossed the belt on and pulled the release on the tensioner. Its started/ran perfectly so I was quite pleased. Not bad for a back yard, 16 year old doing the job. Haha
Old 12-12-2014, 02:29 PM
  #30
Trenklege's Avatar
Yes that is correct. I lined up all the timing marks on the cams and crank, just got it all put back together and now the truck won't start. It wants to, it's turning over and it acts like it wants fuel. I did have a leak at the thermostat because we forgot to tighten down the bolts. We were able to tighten and stop the leak. I also heard one knock the first time I turned the key. The water pump and tb was just replaced two years ago by a mechanic and he did a poor job. Wondering if he didn't time the crank and that's why it's off an in or it slipped. Belt looked like new.
Old 12-12-2014, 03:26 PM
  #31
rworegon's Avatar
What mark on the crank gear did you line up to the oil pump? Hopefully, it was the small dimple that sits below one of those small teeth on the crank gear.
The right hand picture in post #5 shows the proper crank TDC alignment: https://www.yotatech.com/forums/f120...-5vzfe-285210/
Did you replace the front seal and possible bend or break off on of those crank timing gear teeth?
You do have the intake all installed and all electrical connections are nice and tight?
Old 12-12-2014, 05:13 PM
  #32
Trenklege's Avatar
Yes I linedit up with the dimple and rotated it two times and all marks lined up. I don't think a tooth is broken because I didn't touch the seal.
I'm taking it apart tomorrow to check all the electrical connections. Any other suggestions for me to check, Double check? Thanks
Old 01-17-2015, 07:57 PM
  #33
jbar's Avatar
Pin ?.
Originally Posted by fastfox86
Thanks rw. Yeah I read enough DIY's before I started with people having the L and R reversed. I've got it on the correct way and just pulled the pin. I'll spin it a few times after lunch and make sure it all lined up right.
What pin are you referring to? What's its purpose?
Old 01-18-2015, 03:01 AM
  #34
rworegon's Avatar
The pin being referred to is the pin (small Allen wrench, small diameter stiff wire) that holds the hydraulic tensioner is a compressed state while installing the timing belt. The pin is pulled after the belt is correctly in position.
Old 08-05-2022, 02:57 PM
  #35
Caleb94's Avatar
Im new here and just swapped a 5vz in my 94 pickup well i was doing the headgasket and went to install everything and saw my crankpulley sits at the 5 on the gauge by the crank pulley indicating 5degrees advance (that's also what my scan tool says) BUT my crank sproket sits at TDC along with my cams. My question is do I have to reinstall everything and see (what I've been told but see no sense in doing) or can I go ahead and turn it to 0 and install everything?
Old 12-05-2022, 02:58 AM
  #36
mydavestrong's Avatar
They are about a 1/4 inch to the right of the marks on the cam gear backing plate. It looks to me like the belt slipped a tooth and the marks are off now. This isn't surprising since the water pump has had a pretty bad leak and probably got the belt wet.
cbr600rx7
09-09-2018 01:34 PM
RoadRageRock
08-05-2014 03:45 PM
to4menon4u
03-10-2010 03:48 PM
95red4runner
7
07-17-2004 06:21 PM
joe d95
03-27-2004 09:31 AM
Quick Reply: 5vzfe timing belt help
