3VZE horsepower advice
Old 03-24-2011, 06:33 PM
  #41
rattlewagon's Avatar
Woah. No emissions for OBDI vehicles out here, heck, if the cars over 15 years old, you dont even need a title.
Old 03-24-2011, 06:36 PM
  #42
MaK92-4RnR's Avatar
I wish that were the case.
Old 03-25-2011, 03:06 AM
  #43
RBX
RBX's Avatar
Twenty years here, mines Historic....no inspection, no emissions. First thing i did was remove the old exhaust. Next will be the EGR/PAIR. If no other reason, to clean up the engine bay.
Old 03-25-2011, 04:59 AM
  #44
Thats cool! I still need to get a yearly inspection...
Old 03-21-2012, 05:29 PM
  #45
truckmike26's Avatar
Originally Posted by Swimmerboy2112
Everyone who complains about the 3.0 speed should go drive a 22re.
I'd do headers, intake, to help her breathe better and to free up some "power".
Vearing off topic: dumping on the 3VZE is old. It was par for its generation (1987-88: Nissan's 3.0 -- notorious for WARPED, leaking exhaust manifolds, Ford's sorta okay Euro 2.9 V6, GM's hilarious coolant-leaking pile 2.8 V6 and vibrating 4.3 V6 (3/4 350 small block). The bright-spot hero of that era was Jeep's fuel-injected 4.0 in-line six -- 177 hp. It had its problems as well but was smooth and not too bad to work on.
If you squint hard and see the 3VZE as a bigger, smoother 22RE, then it takes the "slowness" out of it.
Old 05-12-2012, 08:47 PM
  #46
rockroller's Avatar
i know this is a old post im a newbe here
reading about the camry head swap on a 3.0 ?
few poeple talked about it will it work ?
also for the exhast i have a t100 think the exhast is 2.25 going bigger to 3 inch with a free flow muff ?
also about the timing ? stock is 10 dec moving it up to 12 ?
Old 01-19-2016, 12:22 AM
  #47
jeremyt's Avatar
So i have spent multiple years of my life driving a 22re, a 3.0 and now a 3.4sc. The most years by a good margin where spent behind the 3.0.
When I was 17 I purchased a 22re 2x4 for a honey pot of a deal. Guy was a great friend, he had replaced the suspension front and rear from a 4x4 to give it a sportier stance. A hoot of a truck, pretty guttless overall if your talking raw numbers but the little 4banger FELT zippy. Lots of teenager shenanigans where endured by it, Full throttle clutch drops yadda yadda.
This thread has tons of info i was agreeing with 100%, except one tiny tiny tidbit, someone said the 22re is not receptive to mods. Ive spent a day on the trail with a LE 22re and its way way more solid than you would think possible from a old 4cly engine. Huge dollars though. But it screamed. hands down screamed, it was rad.
When I went to replace the 22re I thought a little more bottom end oumf would be just the ticket (sold 22re due to needing 4x4) for some of the tighter tricker offroading we have here in the pacific NW. The v6 didnt disappoint in the extra grunt, the thing takes a real ham to bork offroad with. Stock gearing with the 3.0 and low gear 1st is some SERIOUSLY good gearing for all but the trickiest maneuvers. it really has an incredibly forgiving power curve for most offroad situations. But it doesn't have that happy to rev zip feeling the 22re does for flogging and generally aping around. Both engines struggle with hilly roads and elevation. They just dont have that much there. BTW i ended up with 660k on the truck after 2 engine swaps. The engine is eating coolant a bit again. Im a crap 3.0 owner, i jump in on the coldest day and jam. Its been my thrasher for 18 years or so now.
I just bought a 3.4 w/ SC swapped rig. It rocks. I like it so much i let it warm up before i thrash it and everything
Old 10-05-2017, 10:11 PM
  #48
Dans91_yota's Avatar
You can advance the timing a little, up to about 13-15 for some free HP. Id put money into gears before the motor.
Its not a fast motor. And go fast parts are very expensive and dont do a whole lot. Just keep it running good and youll be fine.
Also, do you have enough stickers on your truck? Could try adding a few more. Everyone knows stickers=hp
Oh my hell... LMAO enough stickers hahahaha
The following users liked this post:
Riplayne (12-05-2019)
Old 10-12-2022, 07:22 PM
  #49
93yotaT100's Avatar
Originally Posted by nix4x4
The 3.0 is the worst engine ever made. All they do is blow headgaskets.
They claim 150hp but its more like 115hp tops. They're complete junk
and no one should ever own one. If you just ought one, you screwed up.
Chances are, it'll take a crap on you within a years time unless you change
oil every 1200 miles, and even then its iffy. Sorry about your luck.
There have been half a dozen threads asking this same question this week.
Search.......
PS the answer is "Not a whole lot you can do."
lol my 3vze is at 368,000 kms and going strong. Still no headgasket in my ownership since 288,000
Antsaldana (11-26-2022)
Old 11-26-2022, 01:22 AM
  #50
mydavestrong's Avatar
Do at least a catback exhaust, and do the ISR mod. Those mods will likely cost you the least, and you will definitely gain something.
Old 11-26-2022, 05:37 AM
  #51
RBX
RBX's Avatar
what have you done to the engine? Exhaust bypass? Delete EGR? ISR mod? Curious since my 3VZ had 246k miles when I yanked it out. But my engine was abused badly before I got it.
Old 11-30-2022, 01:53 AM
  #52
It is far superior to todays engines, with it's fuel injection, and 150 horsepower from just 3 liters. And the Fuel efficiency is mind blowing.
AdamP
09-30-2012 04:25 AM
premirrider
07-26-2007 03:25 PM
red 59
07-18-2004 06:32 PM
all4runner
07-26-2003 01:30 AM
Amir904
26
05-21-2003 03:54 PM
Quick Reply: 3VZE horsepower advice
