3rd member swap
Old 11-12-2013, 12:51 PM
turtledogg's Avatar
3rd member swap
I have a 91 toyota with a tacoma rear axle(elocker) that is not hooked up. Im doing a 3.4 swap and an SAS, my question is I have a 3rd member from a T100 rear axle with a locker and 4:88's, will this fit into the tacoma elocker axle(4:10/4:11 gears)? I will be running 35's and this will save me alot of time and money....
Old 11-12-2013, 05:21 PM
rokblok's Avatar
I don't believe that the T100 and Tacoma/pickups share the same size diff. The ring gears are different sizes I believe. The T100 is closer or the same as the Early Tundras.
4x4wire, I believe, has all the year relevant sizes. I will try and find the link.
http://home.4x4wire.com/erik/diffs/
Same size ring gears, different set up internally (trusses help strength)
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
BeMiceElf
10-10-2015 09:40 PM
93toyoguy
08-02-2015 07:41 PM
Quick Reply: 3rd member swap
