33's on 4x4 86 pickup no lift or cut?
Old 08-04-2008, 01:14 PM
dj-86yota's Avatar
hey. just curious if i can fir 33x12.5 tires on my 86 toyota pickup without a lift or cutting? any help is appreciated.
Old 08-04-2008, 01:28 PM
83's Avatar
From your avatar it sort of looks like you have a lift...
I may very well be wrong but I think 31's are the biggest you can fit without a lift. Someone will correct me if I'm wrong.
Old 08-04-2008, 01:29 PM
Evil.Dingo's Avatar
They will fit. .....They will suck power without gears......They will probably rub on serious stuff...... But yes they will fit.
bigt's Avatar
32s fit without a lift...
my new 1987 green pickup stuffs 35s but they musta did some tweaking there lol
Old 08-04-2008, 01:33 PM
taandctran's Avatar
I have a 85 with 33 12.50 on it. with a 4 inch suspension lift. under full stuff and turning about mid way it rubs alittle.
Old 08-04-2008, 03:08 PM
ILLINOISYOTADAWG's Avatar
i have an 86 xcab with 35"'s on it i had 33's and it rubbed a little i had to put a 4"lift to clear my sas'd front end
Old 08-13-2008, 11:02 AM
gentry20's Avatar
i have a 91 pickup no lift with 33/12.5 swampers that only rub when you turn real sharp and turning while going over rough areas
Old 08-13-2008, 11:11 AM
Azusacanyonbogger's Avatar
what size rim are you on? with my 33x12.50x15's on 15x10 welds there was no way in hell. a cheap 3" body lift will fit those tires no prob. you prob have to remove your factory lower valance and smash back some parts inside the fender well. but they fit great with just the 3" body lift and its cheap! no rubbing even when going up steep inclines or anything.
Old 08-13-2008, 11:21 AM
gilby4runner's Avatar
dont do a 3" body lift....
Old 08-13-2008, 01:11 PM
norcalsvx's Avatar
does someone ask this ?? everyday
Old 08-13-2008, 01:13 PM
At least he didnt ask about 35's and no lift
If the rig in question is the one in your avitar it seems like you have a little sag in your rear end. You might as well lift it the right way and replace your leaf springs. If you do a body lift you will still have the sag.
Old 08-13-2008, 01:45 PM
4Crawler's Avatar
They will fit and long as you don't plan on driving it much. A buddy put those on his '94 and he had bad rubbing up front even pulling into a driveway, to the point steering was limited. We did a 1.5" torsion bar crank, 2" longer rear spring shackles plus an add-a-leaf and a 1" body lift plus some front fender trimming to fit them. They still rub a little off-road, especially if he has brand new tires (full diameter):
More info:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old 08-13-2008, 02:11 PM
Yoda's Avatar
I bought my 33-9.50 /15 from a guy with a stock PU because they rubbed. 12.50's will rub for sure.
Old 08-24-2008, 05:00 PM
dj-86yota's Avatar
alright thanks guys. i wasn't actually planning on increasing my tire size with out a lift. i was just curious if it was possible. but thanks for the help.
Old 08-24-2008, 05:28 PM
red87's Avatar
33X10.5s should fit with no lift and no rubbing. I'm not sure if you'll need to flatten the pinch weld or not though..
Old 08-24-2008, 08:06 PM
tc
tc's Avatar
x2
On an 86, you will have to do some pinchweld beating
Old 08-24-2008, 08:17 PM
n16ht5's Avatar
hollly cow... way overaskkedddddddddd.........
if you are willing to mod, they will fit
if not, run 33x1050s
make sure you dont have too much offset
Old 08-05-2009, 09:31 AM
moua1983's Avatar
Talking axle+tranny+transfer case fluid
if they fit run em
Old 08-12-2009, 11:38 PM
hellfire's Avatar
38s fit on stock 4Runners/Trucks with alot of cutting....
Old 08-16-2009, 08:49 PM
Camoyota86's Avatar
i had 33x13.5 ltbs on my stock 86.. also got 3 1/2in out of my torsion bars
Quick Reply: 33's on 4x4 86 pickup no lift or cut?
