2TR-FE ECU Pinout diagram
Old 08-03-2009, 07:49 PM
xtremez's Avatar
Guys,
I'm in search for ECU Pinout diagram for 2008 2TR-FE.
I've searched the forums but couldn't find it.
Can you give me some directions ..
Thanks,
Old 08-03-2009, 08:01 PM
RMA
RMA's Avatar
I dont think you will find it here .
but try this
https://techinfo.toyota.com
its all I got for you man!!
Old 08-04-2009, 02:59 AM
xtremez's Avatar
Thanks RMA...
but need to subscribe to get access
Old 01-23-2019, 04:04 PM
fj40pinobilt's Avatar
Originally Posted by xtremez
Thanks RMA...
Don't know if you have found a free one or not but here is where I found mine.
http://ncttora.com/fsm/05+/index.html
If that don't work, try this http://web.archive.org/web/201011270...05+/index.html
Old 01-23-2019, 04:06 PM
...and if that don't work goto https://www.toyota-4runner.org/redir...a.com%2FFSM%2F
and search around. The other two links are from the site but for whatever reason when I text click on them they don't work.
Old 05-18-2019, 08:05 AM
Next step: Finally got around to pulling the motor and transmission from the Hilux. It wasn't bad and I ended up getting it done by myself. I unbolted the motor from the transmission and cherry picking the motor from the front and then dropping the transmission from the bottom.
Had to remove the hood in order to pull out the 22r
Time to say good bye to the tried and true 22R
Hardest thing about this was removing the two bolts all the way in the back, sandwiched between the firewall and the tranny, holding the tranny to motor. Took me a good 40 mins to get the bolts out 1/2 turn at a time!!!
Old 05-20-2019, 09:07 PM
thefishguy77's Avatar
Try an many extensions as you have, i had about 36" of extensions. Its worked for me one time.
Old 05-21-2019, 06:49 AM
jakey poo's Avatar
This is what has worked for me in the past
Old 05-21-2019, 10:56 AM
Steven Reid's Avatar
Wireing
Got any info on how much wiring was involved. Like how did you trick the ECU to thinking the auto tranny is still there. Im about to do a reverse swap. Im putting a 90s 22r 5 speed tranny into a 09 automatic 2tr tacoma. I miss the feel of a 5 speed tranny plus the 4 speed auto is gutless in this thing.
moparbay
03-10-2023 03:50 PM
zytra
01-24-2019 03:16 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: 2TR-FE ECU Pinout diagram
