22re driving and motor losted all power and start making noise
Just got my truck back on the road 87 4x4 pickup with a 22re and was driving down the road and start losing all power and motor started making noise. I parked and just got it back to my house and have no idea what happened. Never really done any enigne work and dont no if theres any one out there that knows where i should start looking or at least i could suggested to someone who knows more to look any help would be great i just want to get it back on the road weather it makes sense to rebuild the motor if neccesory... just looking for some ideas
There is both oil and coolant in the truck. there seems to b some oil in the coolant tho... i have pulled the valve cover and the timing chain seems to b a little loose but as i said im not to sure how it is supposed to be never really worked on a motor i got the truck last year and drove it for work and have just started to get into addin somethings and just happened. The truck will still start but doesnt stay running unless u give it gas...
Oh sorry the temp seemed normal truck wasnt running very long i was only about 10 mins from home i drove it the day b4 for about ten miles it just got inspected with always perfect emissions and everything truck sat for alittle while i was waitin to buy tired and didnt have the cash and need them for inspection not long tho like 2 months but i started and drove it close to home during that time and had no problems and even the day i brought it home for the shop it was fine it all seems to happen very suddenly not saying something might of been wrong b4 hand but it seems fine and this was very noticible where i couldnt barely get the truck to move cause of the lost of power i pulled it over in the 1st place i could
what sort of noise was it making? I'm almost thinking something to do with the timing chain gave way and it skipped a tooth.
But its just a shot in the dark at this point.
I am no specialist here, but it sounds to me like your timing chain & cam are out of their proper valve timing setting. I recently found out mine was two teeth out causing the motor to run lean among causing a few other problems. If you do not feel confortable working on it yourself, have a mechanic buddy take a look. If you've got a haynes manual it will be able to tell you the proper timing setting with the alignment of the puch marks on the gear. For all you know it could be that the plastic nylon chain guides have worn out causing a slack in tension and it to skip a few teeth. You mentioned a noise sounding like something hiting something else; Be careful and check under your head to see if your valves are in one piece and there is no damage to them or the pistons. Good Luck!
I had friend of mine stop over who is pretty good with motors never worked a toyota but has rebuilt and swap out many others b4 we took the valve cover off and got a good look at the timing chain and as even tho he said it seems a bit loose he wasnt sure that was it so and had me start so he could hear the noise and i prob. didnt describe that well its a hard knock that is loud and from hearing it he is thinking something in the bottom end maybe a connecting rod
the1998sr5
10-19-2016 12:48 PM
voiddweller
19
05-02-2016 09:10 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
