22re adding turbo
Old 02-07-2013, 09:10 PM
  #61
85celicagthatchback's Avatar
Yes 7mgte=440cc's
Old 02-08-2013, 09:28 AM
  #62
frm_808's Avatar
Originally Posted by 85celicagthatchback
Yes 7mgte=440cc's
Thanks,
What other forums are you under?
Old 02-08-2013, 11:45 PM
  #63
Non if u have a 22re with the stock ct20 turbo and u run the stock 6psi and have the stock ret ecu and afm ull only need to get 440cc injectors to keep it together and back the timing down to zero why pin.the conector
Old 02-11-2013, 08:12 PM
  #64
frm_808's Avatar
Confused on that part....
Old 02-13-2013, 12:08 AM
  #65
Confused on what part
Old 02-13-2013, 04:52 PM
  #66
frm_808's Avatar
why pin the connector??
Old 02-13-2013, 06:19 PM
  #67
That's how ur sapose to set the timing
Old 02-15-2013, 07:11 PM
  #68
frm_808's Avatar
I know that, you were asking "why pin the connector" and i had no clue what you were refering to.
RatOmeter
10-22-2015 03:17 PM
toofly1999
07-25-2015 07:09 PM
TURBOrunnerNM
07-20-2015 08:31 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22re adding turbo
