20r/22r hybrid ???'s
Old 06-26-2011, 07:45 PM
1986yota4x4's Avatar
Question 20r/22r hybrid ???'s
ok so here is the deal, my buddy is gonna sell me a 22r with bad bearing and another block and head. the other block is a 22r block and a 20r head. the 22r has a brand new oem cam in it with like 300 miles on it if that, and my plan is to rebuild the 22r and put the 20r head and i was wondering if the 22r oem cam would work in the 20r head.
Old 06-27-2011, 05:57 AM
xxxtreme22r's Avatar
cam will work, but head will only work if the block is an early 22r block. A late block won't work.
20R/22R Hybrid info. Everything you ever wanted to know: http://www.toysport.com/technical%20...tech_notes.htm
Remember this combo only works well with the 20r head that has been ported and larger valves installed. And if you have a later model truck your exhaust manifold will not work. Also IIRC the 20r intake manifold must be used, but I could be wrong.
Old 06-27-2011, 11:52 AM
thanks
06-01-2021 01:51 PM
wimpywade94
02-16-2008 07:43 PM
insane04
08-04-2006 06:26 PM
Phssthpok
05-06-2006 11:55 PM
Quick Reply: 20r/22r hybrid ???'s
