TOYOTA TECH OR OBDll GURU'S ?
Old 05-27-2008, 06:45 PM
DIHOWARD's Avatar
I Have An '03 V6 4runner. I Pulled A P0022 Code From My Scanner (camshaft Position Actuator A - Bank 2 Timing Over-retard).
Cd That Came With The Scanner Says "fuel Air Metering Auxillary Emission Controls"
SHORT TERM FUEL TRIM 2.3%
LONG TERM FUEL TRIM -9.2%
Question Is This: Do These Engines Have Variable Timing / Camshafts? Will A Bad Maf Cause This?
I Do Have A K&N Intake With The Stock Sensor & 63,000 Miles On It.
Any Input Would Be Helpfull.
Old 05-27-2008, 07:41 PM
toytech76's Avatar
Yes. You do have a VVT-I engine. More than likely its a bad actuator or solenoid. Check with the dealer, there may be a TSB on that problem and you can get it covered for free. Your MAF will not cause that problem. Some of the toyotas/scions with the 4 cyl vvt-i engines have that problem and have a tsb on them, so it would be worth calling the dealer and looking into. I will see if I can find anything out tomorrow when i am at work
Old 05-27-2008, 09:54 PM
JamesD's Avatar
You have a bad MAF. Taco's are know for having bad MAF's. Sometimes cleaning them do help.
James
Old 05-28-2008, 04:48 AM
toytech76's Avatar
He doesnt have a fuel trim code or a MAF code. How did you come to your diagnosis???
Old 05-28-2008, 05:12 AM
zlathim's Avatar
James
Good question. I was wondering the same thing.
Old 05-28-2008, 09:51 AM
DIHOWARD's Avatar
Here's The Problem.
High Ratio Of Injector Cleaner To Gasoline.
Filled The Tank And Poof, Codes All Gone!
Lesson Learned, Thanks For Looking.
Old 05-28-2008, 10:16 AM
toytech76's Avatar
hmmmm...I honestly dont think that was your problem. Here is an excerpt from the repair manual.
(a) Clear the DTC.
(1) Operating the hand−held tester to erase the codes, or disconnecting the battery terminal or the
EFI and ECTS fuses more than 60 sec.
(b) Start and warm up the engine.
(c) Drive the vehicle around for 10 minutes or more.
(d) Read output DTC using the hand−held tester.
Standard: No DTC output.
HINT:
*: DTCs P0011, P0012, P0021 or P0022 is output when a foreign object in engine oil is caught in some part
of the system. These codes will stay registered even if the system returns to normal after a short time. These
foreign objects are then captured by the oil filter, thus eliminating the source of the problem.
OK VVT SYSTEM OK *
Old 05-28-2008, 10:17 AM
toytech76's Avatar
Your emission sysytem shouldnt have that affect on your vvt-i system. Your fuel trims will be off if the vvt-i systems is malfunctioning. If it was just a particle in your oil its probably gone. Other than that i'm still willing to bet its your actuator or solenoid
Old 05-28-2008, 04:19 PM
DIHOWARD's Avatar
all the scanner reads now is "pass"
there is no other info. the scanner that i have also checks for emmission problems, what should i be looking for?
Old 05-28-2008, 05:27 PM
HAVOC's Avatar
There are little screens that capture particles so they don't intefere with the VVT-i actuators. I've only see them get clogged on engines where somebody never change the oil. You may have one that is dirty (Bank 2).
Old 05-28-2008, 08:34 PM
JamesD's Avatar
Oops! My bad I read it wrong.
Sounds like the actuator is sticking for the camshaft. I would try to clean it if you can.
James
Old 05-29-2008, 07:28 AM
DIHOWARD's Avatar
Oil Changes Done Religiously Every 3k. Went To Synth Blend After First Oil Change, Now Running Amsoil For The Last 15k. High End Filter As Well. Probably Not An Issue Here.
Old 03-11-2017, 06:44 AM
puckoach's Avatar
Bump
I have similar problem. 2005 6cyl 4runner.
Purchased a year ago, with 62,000. Code popped up almost right away. Despite resetting a number of times, always returns.
Need a sticker now. 82,000.
Used one from of cleaner. Code returned
Actuator replaced, code returned.
Next plan is a better brand of cleaner. Suggestions ?
Alternate suggestions ?
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
nick b
07-11-2015 04:38 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: TOYOTA TECH OR OBDll GURU'S ?
