2006 Tacoma turn traction control OFF!
Old 09-18-2011, 03:55 PM
Hunter2-4's Avatar
Unhappy 2006 Tacoma turn traction control OFF!
Hey, I just got a 2006 tacoma and I really want to turn all the traction control off. I searched and i didn't find anything about it. This is the model year before the off switch installed.
Can i install the switch myself, will the ECU accept the switch?
Is there any other way around it without turning 4wd on?
Please help!!!!!
Old 09-18-2011, 04:17 PM
ravenlord's Avatar
If you can accept an ABS light on at all times, and like to drive without ABS brakes disconnect an ABS wheel sensor. It will kill the traction control.
Disclaimer: I do not advise doing this, as it will cause "safety" features of your vehicle to function improperly, and put you at risk of lawsuit if you do get into an accident.
Old 01-02-2012, 04:59 PM
Rado_Taco11's Avatar
You can disable the traction control by following the these steps:
1. Start the truck
2. Before you move the truck - Push and hold the TRAC button for ~3 to 5 seconds
You have to do this every time while you are stopped/parked for every key cycle but it works and it doesn't cost you anything.
Old 04-21-2013, 11:59 AM
adam2562's Avatar
Rado... can you read? he has an 06 model that doesn't have the TRAC button. hate when people give bad information
djpg2000
11-11-2020 04:56 AM
nick9455649
09-11-2015 05:10 PM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: 2006 Tacoma turn traction control OFF!
