ZUK Mod - No Cut - 96-98 Runner Coil Springs
Old 04-24-2011, 11:56 PM
ToyoTech559's Avatar
Originally Posted by VonMussa
http://www.usedpartslive.com/catalog...3369+1725+9408
think these rears would work for the weldless method?
i cant say for sure. but they do say its a factory replacement. as long as they are 96-98 springs. it should work. might be able to save some money if you look for a set of used springs from guys that did lift kits on their 4runners
Old 04-26-2011, 03:15 AM
92 TOY's Avatar
looks good.
now i am confused and intrigued by the no-cut method but confused in as much as now i don't know what springs i should be looking for. not really wanting to cut anything, this looks waaaaaaay easy.
dangit..now i gotta search more.......unless, of course, someone want to post up exactly what i will need for my son's 88 4runner to do the no-cut. (pretty please)
not going to run to the junkyard to get anything, so i am mostly only interested in what size springs to buy......i like the spring compressor trick.....cuz, i'd like to keep all my teeth
Old 04-26-2011, 03:26 AM
xxxtreme22r's Avatar
I know where there are plenty of used Heep springs. I am willing to grab some for people if they want to go this route. Just need to let me know which ones you need so I grab the right ones.
Old 04-26-2011, 03:47 AM
92 TOY's Avatar
is this it????
http://cgi.ebay.com/ebaymotors/NEW-R...Q5fCarQ5fParts
Old 04-26-2011, 05:31 AM
  #25
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
Originally Posted by ToyoTech559
its not because the brake fluid is dirty. its cuz the LPSV thinks that i have no load in the rear so it takes away if not all the rear braking. i did a simple test by stopping a certain way that i know will cause the sudden jump but i pulled on the ebrake so i know the rear brakes are on. release ebrake and took off. no sudden jump felt.
im thinking of disconnecting the rear LPSV that is bolted to the rear axle housing. take the rod and move it all the way up to the body and zip tie it. this will allow the LPSV to think i have the rear loaded and give me my rear brakes back.
The LSPV still won't work right even if you modify it like this, you're better off getting a manual bias valve and getting rid of the LSPV entirely if you have lift.
Old 04-26-2011, 05:57 AM
  #26
LPSV extension bracket works pretty well for any size lift. Just got done with making my 2" one. See my build thread for more.
Old 04-26-2011, 08:00 AM
  #27
ZUK
ZUK's Avatar
Originally Posted by 92 TOY
Those are 5" OD.....not sure of the exact ID so I sent the seller a question what it would be for the 125 pound rated coil. Let's see what happens.
Old 04-26-2011, 08:21 AM
  #28
92 TOY's Avatar
thanks much......because it's a no-modification fix, me likes it alot.
Old 04-26-2011, 08:41 AM
  #29
ZUK
ZUK's Avatar
Hopefully, I'll get an answer in a couple of hours....but I saw they also sell them in a longer 16" fyi
Old 04-26-2011, 10:21 AM
  #30
anthony1's Avatar
Don' t zip tied the LPSV. You can make a bracket to raise the mount location on the end of the arm, get a new LPSV that has manual adjustment or do what I did which is to cut it and get a turnbuckles so you can adjust the level.
http://www.lowes.com/pd_22225-1277-M...%3Dturnbuckles
I remove one of the loop bolt. I use a bolt and a nut to fasten it on the cross member. feed the arm through the loop. I'll see if I can get a pic up.
Old 04-26-2011, 09:18 PM
  #31
thanks. i just made a bracket for now. it still jerks as before. i need to get correct shocks asap. i have a feeling that the shocks are maxed out and causing the rear axle to flex forward and backwards instead of it being transferred into the dampers
Old 05-03-2011, 07:33 PM
  #32
whats the best and cheapest way to extend the rear brake line. im gonna be getting new shocks so i can get the full travel of my suspension (another 2 inch) pretty sure the brake lines wont be long enough
Old 05-03-2011, 08:14 PM
  #33
anthony1's Avatar
Cheapest?....um..I think you can extend it by adding another brake line to it.....junkyard front brake line. Having said that, I don't recommend you go "cheap" on the brakes.
You can get longer brake line pretty reasonable price at Autozone.
Here's the spec for stock line..87 4runner.
Brake Hose Assembly Length (In): 17
End 1 Fitting Material: Treated Steel
End 1 Type/Size of Fitting: Male - M10 x 1.0
End 2 Fitting Material: Treated Steel
End 2 Type/Size of Fitting: Female - M10 x 1.0
Here's a 2005 tundra V8 rear brake line
Brake Hose Assembly Length (In): 20.5
End 1 Type/Size of Fitting: Female - M10 x 1.0
Looks the same except it's 3.5" longer.....for about $26 +tx.
Old 05-03-2011, 09:21 PM
  #34
guess cheap was the wrong word. i just want the simplest way to extend the brake line without having to go thru too much trouble. thanks for the info. i will be ordering one soon. thanks again for the quick reply
Old 05-03-2011, 09:33 PM
  #35
malteserunner's Avatar
Close, but not quite the same. You could use this hose with a male/male adapter, though.
Old 05-04-2011, 09:24 AM
  #36
anthony1's Avatar
I didn't see that....thanks. Maybe another model/year might do it...
Old 05-05-2011, 09:56 PM
  #37
found it. 2000 tundra V8 4WD has the correct brake line. i just order one from autozone for like $22 taxed.
Old 05-06-2011, 07:40 AM
  #38
anthony1's Avatar
Thanks for letting us know. What is the length on this one?
Btw, the 2nd gen. 4runner rear brake line is shorter...like 14" instead of 17" on the 1st gen.
Old 05-06-2011, 04:37 PM
  #39
parts come in this saturday when i will be installing new shocks as well. N98 and N94
88 4Runner V6
2000 Tundra V8 4WD
Brake Hose Assembly Length (In): 20.25
Old 05-26-2011, 11:36 AM
  #40
ZUK
ZUK's Avatar
...might be. dlucky894runner just ordered those coils so let's see what he finds.
https://www.yotatech.com/forums/f116...ptions-235742/
Is there a 4x4 lift shop near you? They might have some stock front TJ coils that they will give you free or a small charge. They always end up in the dumpster behind the shops
Quick Reply: ZUK Mod - No Cut - 96-98 Runner Coil Springs
