Your thoughts 5VZ-FE Vs. 1UZ-FE
Old 10-26-2012, 06:13 AM
Belize Off Road Team's Avatar
Talking Your thoughts 5VZ-FE Vs. 1UZ-FE
Okay so i have a 93 Toyota Pick up with the 3.0L, its running great, 23MPG, but its been abused in the past and is starting to show it.
So after a talk with some friends we are going to swap a bigger motor come spring time and I'm looking for something that is going to move my truck like nothing.
i know a fair bit about the 3.4L and very little about the 4.0L V8.
whats the difficulty of swapping in a 1UZ? what mods are needed to fit the 1UZ vs the 5VZ? Whats the cost difference?
I need to know what to start saving for XD
Old 10-26-2012, 06:15 AM
waskillywabbit's Avatar
3.4 is a much easier swap as many things are the same.
4.0 or V8 swap everything is different.
:wabbit2:
Old 10-26-2012, 06:36 AM
would the Auto from the 3VZ-E work on the 1UZ? hows the harness swap with the 1UZ? I guess my biggest question is, do the benefits and power gain from a 1UZ swap out-weigh the extra work needed?
Old 10-26-2012, 06:43 AM
No. It's all different obviously.
IMO it's not worth the exponentially more amount of aggravation.
3.4 swap is easy with the right donor and knowing what you are doing.
:wabbit2:
Old 10-26-2012, 08:10 AM
iliketoyota's Avatar
what about a swap from a 22re to a 5vz vs a 1uz? would that change anything? i have been thinking alot about motor swaps lately.
Old 10-26-2012, 08:40 AM
MudHippy's Avatar
No, it wouldn't.
You would still need to swap in EVERYTHING from the 1UZ donor vehicle. As in ALL the electronics(ECU, wiring, gauges, fuel pump, etc.). And then some(like the transmission and radiator). And have to fab a number of other things(like motor mounts, transmission crossmember, driveshafts, exhaust components, etc.). Plus buy an adapter to fit a transfer case to the Lexus transmission.
https://www.yotatech.com/forums/f161...0-3vze-185324/
https://www.yotatech.com/forums/f199...runner-228824/
Old 10-26-2012, 08:59 AM
donomite49's Avatar
stay with the 3.4.
i used my gear drive TC and stock driveshafts.
it's hard enough but worth it imo...
200hp stock or 300hp with modded sc is plenty of power.
Old 10-29-2012, 10:05 PM
Aznwolf118's Avatar
I am in the middle of a 1uz swap now and I have been in 2 other 1st gens with the 1uz swap and that sealed the deal for me.
Old 10-30-2012, 06:52 AM
Originally Posted by MudHippy
No, it wouldn't.
What i meant was since things like motor mounts and transmissions arent the same from the 22re to 5vz-fe like they are on the 3vze and 5vz. Would just going with a 1uz be not much more work?
Old 10-30-2012, 07:04 AM
TNRabbit's Avatar
I was going to do the 1UZ swap about 5 years ago, but after talking with a TON of folks at other forums as well, decided it was going to be too spendy & time consuming. Then when you're done, you STILL have to find a suitable cooling system to CRAM into what space is left. Can it be done? Yes. Is it worth it? Only you could answer that, but I had at least two folks who tried it advise me to drop the attempt.
Old 10-30-2012, 09:08 AM
yeah your probably right. Ive heard 22re to 5vz isnt real easy too though. But at least you could have the cooling and fuel system already there. Another thing is the r150f transmission will bolt right into the frame with the crossmember from the v6 truck. Really the motor mounts and wiring are the only custom thing with the 5vz i guess.
Old 10-30-2012, 11:19 AM
donomite49's Avatar
you also have room to work on the v6 under the hood.
plus double the HP of the 22re feels like plenty of power.
and if that's not enough you can sc, tune it, and triple the HP of the 4 banger.
Old 10-30-2012, 01:26 PM
Aznwolf118's Avatar
Something sexy about a V8 hiding in a 1st gen though. But thats just me.....
The 3.4L is a great motor and has served me well in my 02' I can tell you the motor has been trd supercharged and urd 2.2/7th injected and has over 125k trouble free miles charged on stock internals.
The transmission is the weak link.
snosurfer
3.4 Swaps
03-29-2016 11:29 AM
AndYota
08-10-2015 09:19 AM
Edionne13
07-09-2015 01:59 PM
Quick Reply: Your thoughts 5VZ-FE Vs. 1UZ-FE
