Wrist Pin Assembly
Old 04-04-2008, 10:43 AM
DanStew's Avatar
Wrist Pin Assembly
I am assembling the pistons to connecting rods. The pins slide easy in the pistons but are not sliding in the connecting rods. Do i have to press these in or are they suppsoed to be a slip fit?I installed the new bushing in the connecting rod already .
Old 04-04-2008, 10:54 AM
TOYOTA 1's Avatar
no they are pressed in
Old 04-04-2008, 10:56 AM
DanStew's Avatar
Thanks!
TOYOTA 1's Avatar
i usually have the peeps that do my mchine work press them for me! i think those brass bushings in the rod also have to be fitted/honed for the correct fit for the pins! not shure on that though!
ohh and this is a 4cyl rite? i have never built a 3.slow!
Old 04-04-2008, 11:23 AM
DanStew's Avatar
yup 4cyl
Old 04-04-2008, 01:54 PM
dcg9381's Avatar
I'm not so sure about that. I've never had to press the wrist pins into the rods.
Old 04-04-2008, 02:50 PM
DudeBud's Avatar
they are not press in they are floaters thats why they come with wrist pin clips. when installing bushings in the rods most of the time you will need to have the small end honed
Old 04-04-2008, 05:28 PM
TOYOTA 1's Avatar
thank you on the corection! like i said i usaualy have the machine shop hang mine on the rods. sorry for the misleading info!
i guess i got mixed up. the brass bushing i belive has to be pressed in then honed to fit your wrist pin. then clips hold piston to the pin.
Old 04-04-2008, 10:37 PM
Pistonman's Avatar
Aside from the bushing fit, I usually put the piston in boiling water for a minute or so, oil the pin on assy also.
Old 10-21-2016, 09:40 AM
Jean Fogarty's Avatar
Old 10-21-2016, 09:44 AM
wrist pin bushing
Originally Posted by Jean Fogarty
I. Know they have to be honed but my question is. What's to loose
punks_is_4x4
02-26-2016 04:29 PM
voiddweller
10-02-2015 07:47 AM
LCE_Performance
10-01-2015 01:03 PM
tylermx71
09-29-2015 08:49 PM
runnermedic
13
09-21-2015 05:20 PM
Quick Reply: Wrist Pin Assembly
