Wiring Diagram explanation
Hi
I have an easy question for you guys.
My wiring diagram is in english and my language is norwegian = don't understand everything.
On the wiring diagram alternator it reads L - B - S and IG, what says ?
I'm trying to wire my alternator, as there was a 3Y engine in it before and now there is a 22re.
But in the meantime there was a V8, and alot of cutting and crap has been done = big mess in the fusebox on the right fender.
If anyone have a picture of this box, inside and underneath it would have been GREAT :
Also, how big is the black and green fuse here ? I can see the red one is 30A.
Underneath :
Underneath :
IG is ignition (+12volts when key is on). L is to the alternator light. At ground when the alternator is not turning, 12v when turning and producing power. B is the separate heavy-gauge wire that is the output of the alternator. It goes directly to the battery through an 80amp fuse. S (which I believe 'means' stator) is to the B line, through a 40amp fuse. It supplies the 12v from the battery to the stator, which allows the alternator to produce power.
IG, L and S are in one connector at the alternator, B is a separate line to the copper stud.
On my 1994 v6, I have four "big" fuses; the 80 and 40 referred to above, and two 30s for the heater fan and the "AM2" circuit.
Your fuse box appears different from mine; you'll find better help here if you specify your year and engine size (though I realize, in your case, things may have been changed around a lot).
Good luck, and welcome to Yotatech.
Without seeing what you have... that makes it difficult.
The alternator should have a post connection and a 3-wire plug. The post connection is a heavy gauge white wire which goes to the battery. In the 3 wire plug should be another smaller white wire (which is parallel to the heavy white wire) and should have battery voltage all the time, a yellow wire which interfaces with the charge light on the dash, and a red wire which is hot (has 12v) with the key on.
heres the pirate thread abe, its a 85 hilux he says.
http://www.pirate4x4.com/forum/showthread.php?t=812073
Yes, its a 85 Hilux. Used to be a 3Y in it, but now there's a 22re. In between there was a V8. This is a half-finished project I have bought, and I'm trying to figure out what's been done and put it back together how its supposed to be.
Ok, finaly had time to look at this mess.
Apparently there has been a separate regulator, but now the regulator is part of the alternator. At least so I think as the alternator is brand new... is there anyway to tell if it's part of it ?
And what is the little difference in the wiring ?
Bad response here, guess there is no one who bothers to look, but I just continue to throw out questions just incase someone does.
The pink 30A and the green 40A is linked/bridged, need to know the wires connected on the bridge side (where they lead to), can't figure it out from my wiring diagram.
The truck.
The truck.
1 Post
Wow thats pretty nice truck.Asd for the regulators are seperate, but they are putting them on the altenators (as afr as I know, don't quote me on this)Do you have teh diagrams for the truck? Here is a few sites. TIS is a pay site the other is free.
https://techinfo.toyota.com/techInfo....toyota.com%2F
http://www.ncttora.com/fsm/index.html
Hope this helps.
Edit: I just re-read your first post. Sorry
Hope this helps.
theking11863
03-19-2016 09:36 PM
88yodabasket
07-13-2015 01:32 PM
