Why is my truck killing alternators?
Old 10-16-2006, 01:35 AM
vwfastg60's Avatar
So i replaced my motor. All the wiring was checked/cleaned up or even replaced. I have checked my grounds and checked to make sure theres no bad connections or wires grounding out.I killed one up 4wheeling.I was luck i had a new red top and it didnt poop out all the way and i could get home.I replaced it and a few weeks later the other one poops out.I replaced it tonight and drove about 30 miles and went to wash the truck.As i pull up to the car wash my F'n charge light comes on again!!!! What could be the issue? I have replaced it once with a factory one.Once with a Checker one and one is an auto zone. I think i have a used one from my 4runner floating around so i may just throw it in for a few days.....any help would be great.
pic for views
Old 10-16-2006, 04:03 AM
doc76239's Avatar
Well are you running a stock motor? Or do you have a 350 in there??? Did you have the bad? alternator checked out at your local parts store? Any other electical problems???? If your killing new alternators i would think you have a short? Maybe the wrong alternator belt?
Old 10-16-2006, 05:37 AM
TNRabbit's Avatar
You've got a short somewhere. Get the old multimeter out and start checking. My first guess would be any aftermarket electrical items like trailer lights...
Old 10-16-2006, 05:56 AM
snap-on's Avatar
there are very few places you can short the system and 1) not burn out the wires ending the short... 2) not burn out a fuse ending the problem...
i always forget... does toyota use an externaly regulated alternator? if so id say voltage regulator is toast.
Old 10-16-2006, 06:50 AM
Bumpin' Yota's Avatar
internal voltage reg.
Are you using the alternator to charge drained or depleted batteries on a regular basis? If so, then yes you use of the alt is killing it.
BEFORE putting on a new alt, charge up your batteries using a battery charger. Once that's done look for continuity to ground on the alternator's chargine wire....
Old 10-16-2006, 12:46 PM
vwfastg60's Avatar
So im going to pick up another alternator.To answer a few questions,
1.its a 22r motor
2.No aftermarket lighting has been added and the only thing i have changed on the truck that has to do with wiring is a mp3 player and some dash speakers. All wired correctly.
3. the belt hasnt changed from the first one that has been in there for 80k+
4.The battery has been recharged before hooking the leads and starting the truck.
Its a red top so even after the alternator dies and i get home theres still juice in it.Unhooked still reads 12v
the alternator on this one i think is the voltage reg. The alternator is only putting out 2.1v at idle and reving it a bit puts it to 7.1-7.6 thats what the first one did too....same voltage even.
I also have added and just remembered i did it was a regrounding kit. It has 8 more grounds and helped out a lot as far as lighting inside and outside.
I will have a few tested to see what they do but before i put the new one in i will be checking more wires......ugh i hate problem like this.
Old 10-16-2006, 01:02 PM
CJM
CJM's Avatar
Where are you getting the alternator? I wouldnt put anything less than a heavy duty of factory in my truck. The reman ones are junk..
Old 10-16-2006, 01:03 PM
where are all the grounds on the grounding kit routed to? That shouldn't be it but...
Old 10-16-2006, 02:55 PM
surf4runner's Avatar
not in a toy, but the only time i smoked 4 alt (and 1 battery) was due to a bad fusible link it still didnt blow any fuses. when it finally melted all the way, replaced it and the alt and prob solved. HTH.
Old 10-16-2006, 08:02 PM
vwfastg60's Avatar
ok i got an alternator and started to pull it apart.I found that my plug was really dirty and didnt feel like it fit tight.(my friend plugged it in the last time)so i cleaned it up and for giggles plugged it back in....stupid light went off! I returned the alternator and havent had a problem.I think it was the gunk in the plug fryin them. i guess we will see.
The grounds-i put one to the block one to the body by the battery,one to the firewall.one to the frame rail and one to the block. I have heard people talking about how they do nothing but after working on VW's for so long i think that grounds are a good thing lol plus it made my headlights brigher and dash light brighter and the ruck seems to run a tiny bit better. it used to run rich and now its ok i think there might have been weak power to everything.
Old 04-21-2015, 09:19 PM
foxtrotuniform's Avatar
Bumping an old thread to say thanks to this guy right here! Rock on TNRabbit. I was on my third alternator in a month and about to drive my Land Cruiser into the ocean when I saw this post.
Broken trailer light wires were rubbing against my receiver hitch. Snipped them off. Alternator bliss.
You're the man!
Old 04-21-2015, 11:34 PM
wyoming9's Avatar
Red face
This was a case of just changing alternators and never finding the real problem
The plug gets corroded the wire going from the alternator B terminal just gets old and brittle from thermal cycling.
Old 06-07-2015, 10:07 PM
gtct10b's Avatar
bad grounds could also be a problem also, make sure all of your grounds have a clean surface before installing
bigblue82
10
07-06-2015 08:27 AM
MadMax48
07-03-2015 08:26 AM
paxanders
06-21-2015 06:29 AM
Dennis140
06-17-2015 10:37 AM
Quick Reply: Why is my truck killing alternators?
