where is the transmission control module located
Old 06-22-2010, 09:09 AM
jdavis's Avatar
Exclamation where is the transmission control module located
just wondering where the transmission control module is on my 1989 toyota pickup. it is an 22-re with an a/t, 4wd, cruise. i have to start out in low with the shifter and manually shift up. swapped out the tranny and still have the same problem. is there something that i am missing. is it not the control module? if not, what do you think it is. i thought maybe shift position sensor but then people act like i'm crazy when i ask about that like it doesn't have a shift position sensor. does it not?
Old 06-22-2010, 12:34 PM
InternetRoadkill's Avatar
The control module is under the center console in front of the shifter.
It sounds like something is not plugged in.
Old 08-28-2023, 04:47 AM
Yota1993's Avatar
I know this is an old post. But I am having the same issue that you described. I can start out in low and manually shift. Sometimes when I disconnect the ECM for 30 minutes the truck shifts perfect, then it will go in limp mode. I always get a code 63 that indicates the number two shift solenoid. I have checked the solenoids from the ECM and have removed all three solenoids and checked ohms, applied 12 volts and performed the pressure check as described in the FSM. I was checking to see if you figured out your issue.
Thanks.
Old 08-28-2023, 12:37 PM
offroadnutz's Avatar
Every time I've had this problem I replaced the shift solenoids and fixed it.
The following users liked this post:
Yota1993 (08-28-2023)
Korupt
11-02-2019 04:28 PM
RV8guy
10-28-2016 03:45 AM
ricerocket2
09-07-2010 12:44 PM
dh515
11
05-28-2010 10:05 AM
89HiLuxus
03-01-2010 05:07 PM
Quick Reply: where is the transmission control module located
