Where does this yello/black ground wire go?
Old 07-15-2012, 01:37 PM
flatbed's Avatar
This ground is connected to fire wall between the heater hoses. It is black/yellow, 7inches long and has an eyelet on loose end. Maybe mounts to stud that holds vacumm line rails? All my labels came off since starting job. I'm alomst there after doing head/timming job. Gonna fire tonight!!!
Old 07-15-2012, 02:16 PM
slow-mo's Avatar
If the 22RE is anything like my 22R & from your description of where the wire is, that wire mounts to the back of the cylinder head itself. Not the side but the very back. But then again, that is for my 22R.
Old 07-15-2012, 02:25 PM
myyota's Avatar
It can mount to the back of the head, or on top of the valve cover. Ive seen that ground wire mounted to both places, so either place will work.
Old 07-15-2012, 09:44 PM
jerry507's Avatar
Strange, I figured this problem would be easy to solve by consulting the FSM. But it only lists two ground wires with eyelets, mounting down by the alternator and one by the intake manifold. I'd have to check my truck to see if it's there on mine...
Old 07-17-2012, 05:29 PM
flatbed's Avatar
I just ran it to valve cover, looks like previous owner made connection to firewall. Thanks for the help.
Old 07-17-2012, 05:40 PM
rworegon's Avatar
Did you see this?
https://www.yotatech.com/forums/f116...-guide-194413/
Old 07-18-2012, 08:22 AM
jerry507's Avatar
Awesome post. I should check my engine to make sure they're all there. I don't have AC either so I can double check his theory about #1 bolt.
edit - Ah nm, it's clarified later on in the post.
Old 07-19-2012, 06:14 PM
flatbed's Avatar
Wow, always impressed by YOTA YODA'S; that post answered a few other questions. I need to step up my game.
okamikai
04-30-2018 10:19 PM
Doug4320
03-24-2018 10:11 PM
montanatruck
02-26-2017 07:07 AM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
Esibnitsud
07-30-2015 08:19 PM
Quick Reply: Where does this yello/black ground wire go?
