What you need for 22re Intake Mods / Installation
Old 03-26-2009, 09:34 PM
xzyragon's Avatar
Well, threads have popped up about switching out the airbox for a cone filter. IMO, i have heard it is better to just do the ISR swap to get a better throttle response. To go all out, do the battery / intake swap, supra AFM swap, and a cone filter, but here only cone filters will be discussed...
I was forced to just put in an aftermarket cone filter, as airboxes are expensive stock from the stealership, and i can't find junkyards with yota's nearby. Anyway, after a couple trips down to the local pepboys, I had all the parts necessary. I needed:
-3" tubing. I used a flex tube that was $20. Metal 3" tubes are around $40, and the K&N kit goes for $110 with everything.
-Air filter. I used a cheap Spectre Air filter, and it was about $20. Not as good of a rep as K&N, but its cheap . Works fine thus far.
-Mini Air Filter (note this does not stand for MAF ) for the PAIR valve hose if you have one... costs about $5
-Hose Clamps, if you don't have em already. Range in prices, and please get the ones that require the use of a screwdriver.
-AFM to 3" round adapter. From my experience, buy the aluminum one, as it is easier to machine metal. Holes have to be drilled with precision so you don't puncture the round metal tube.
SO... installing everything is EXTREMELY EASY. No joke, its just putting on hoses and clamping em. The hard parts are either machining the AFM adapter, or making mounting brackets for the AFM. I used scrap sheet metal and random steel brackets as well as a drill press to attach the AFM to the radiator and radiator support.
Pictures
full setup
my filter
full shot of hood
Good luck if this is what you plan to do
Old 03-26-2009, 09:58 PM
abecedarian's Avatar
I know what you're missing:
You should paint the valve cover and intake. It'll look super clean... but the added weight of the paint will probably offset the power gains from the cone filter.
Old 03-26-2009, 10:10 PM
toyota4x4907's Avatar
ISR on a 22re?...
Old 03-26-2009, 10:20 PM
Fofo's Avatar
You"ve a loose ground!!
Old 03-26-2009, 10:26 PM
Care to explain?
Old 03-26-2009, 10:44 PM
xzyragon's Avatar
Originally Posted by toyota4x4907
ISR on a 22re?...
just the basic idea of swapping the battery and intake
Old 03-26-2009, 10:46 PM
xzyragon's Avatar
while im at it, i should just take out the bed, doors, hood, fenders, etc to decrease weight so i can afford the painted valve cover
Old 03-26-2009, 10:50 PM
What do you mean 'afford' the painted cover? Cost me about 4 bucks for the can of paint and about a half hour to buff the paint off the "TOYOTA" and "EFI" areas of the valve cover and intake.
If you sold your bed, doors, hood and fenders, you'd have enough money to start production on these items and sell them on ebay for a profit.
Old 03-26-2009, 10:52 PM
xzyragon's Avatar
not in monetary terms, but simply in affording the weight gain by painting the valve cover
But i do plan on painting it metallic red over the summer, as well as giving the truck a midnight blue paint job. Might look interesting
Old 03-26-2009, 11:01 PM
scuba's Avatar
Thats not an ISR mod...
Old 03-26-2009, 11:06 PM
xzyragon's Avatar
then i have been mistaken. Forgive me scuba
Old 03-26-2009, 11:08 PM
xzyragon's Avatar
intake silencer removal. ya dont say
BI swap then
Old 03-26-2009, 11:11 PM
BI swap then
If you're swapping BI's, you must be in West Hollywood.
Old 03-26-2009, 11:26 PM
scuba's Avatar
LMAO
Old 03-27-2009, 12:34 PM
BigBluePile's Avatar
Hey, I just saw this thread and was wondering if it would apply to my 4banger...?
Old 03-27-2009, 12:59 PM
Lumpy's Avatar
I just did mine the other day, got everything I needed from ebay for about $60.00. No drillin required. The mounting brackets don't work well though and I think the pip could be about 5" longer for a better fit. But I plan on doing the bat swap soon. I just got the little cone from PepBoys earlier today and I'll get that on soon. So for now this is it.
Old 03-27-2009, 01:20 PM
This thread IS about 22res, you know....
Old 03-27-2009, 01:22 PM
xzyragon's Avatar
an awfully shiny pipe in an awfully dirty engine bay.
Does the hood close with the pipe that high? it looks like the hood should smoosh the pipe down when it closes. Hope you have no problem with the B / I swap
Old 03-27-2009, 01:30 PM
It IS??
Old 03-27-2009, 01:31 PM
Let me go get my ex so we can bi swap...
Quick Reply: What you need for 22re Intake Mods / Installation
