What have you found in your oil pan?
Old 07-14-2008, 11:23 PM
Matt16's Avatar
I dropped my oil pan today as I had the front diff out anyways and I found
  • one bolt timing chain guide bolt with a gouge in it (likely the one that came loose an severed my chain last fall)
  • a couple links and pins
  • a dozen pieces of timing chain guide, from a previous breakage- last time, my guides never broke.
  • brass wire bristles from when I tried to clean the lip of the oil pan (bottom of timing cover) with a wire bristle brush and the thing wasn't rated for the speed Dremels turn at and it exploded
  • some pieces of rocker (s?)
Now, as I have the pan out, give me ONE good reason why I should not stash one of my spiders gear left over from my diff in there. Now that would screw with the next guys's mind . What would you put it there?
Old 07-14-2008, 11:31 PM
iamsuperbleeder's Avatar
...a bullet shell... or maybe just the lead part of the bullet, and ding a little dent on the side of the pan and make it look like it was patched with a weld...
or maybe a little porcelain budda figure...
that would be random as hell, lmao
Old 07-14-2008, 11:47 PM
Matt16's Avatar
I think a bent valve would be hilarious cause think of the next guy losing sleep imagining how the valve contorted its was up through the valve guides into the rocker cover, then down past the timing chain, past the sprocket and into the pan.
Of course a purple rubber phallus would also be funny.
Old 07-15-2008, 12:12 AM
Originally Posted by Matt16
...Of course a purple rubber phallus would also be funny...
lmao, uh yeah, that would be odd... I think I'd have to leave that in the oil pan if I found that... lol
Old 07-15-2008, 12:22 AM
CyMoN's Avatar
OIL
Old 07-15-2008, 12:23 AM
Originally Posted by CyMoN
OIL
no way... what's that do'n in there...
Old 07-15-2008, 12:33 AM
CyMoN's Avatar
Not only have I found it in there but I have put it in there as well man that will mess with the next owner oh wait there will not be a next owner
Old 07-15-2008, 01:11 AM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
a buddy christ bobble-head, and the phallas......there ya go
Old 07-15-2008, 04:10 AM
bigdaddy87547's Avatar
A muffler bearing.
Old 07-15-2008, 04:28 AM
Robert m's Avatar
i would paint a message on the inside that says "if you can read this, you f#%@^d something up!"
Old 07-15-2008, 05:45 AM
zlathim's Avatar
Oh this is good. I like the bent valve idea the best so far. A complete compression ring would have them scratching their heads for a while too.
Old 07-15-2008, 06:28 AM
pauliep13's Avatar
Originally Posted by bigdaddy87547
A muffler bearing.
Maybe an empty bottle of blinker fluid, too?
Old 07-15-2008, 06:29 AM
axekick's Avatar
A kitten.
Old 07-15-2008, 06:37 AM
stupid_mud_gremlins's Avatar
marbles, toy soldiers, and a hot wheels truck that looks like yours.....
Old 07-15-2008, 06:39 AM
ozziesironmanoffroad's Avatar
once i found a oil soaked just about disintegrated piece of bread in my old chevys oil pan... lmfao dont ask how it got in there, cuz i dont know, im still tryin to figure that one out
Old 07-15-2008, 06:47 AM
Crawdad's Avatar
Found a bunch of bugs one time. Mosquitos, looked like.
The truck had been sitting a while.
Old 07-15-2008, 06:48 AM
iselloil's Avatar
Half a piston,connecting rod,a spun bearing,a shattered oil pickup tube and strainer.
Old 07-15-2008, 07:08 AM
iselloil's Avatar
Oh I forgot,big dents and a hole where the rod came out.But it still ran,with a bad miss and some knocking.
Old 07-15-2008, 07:27 AM
Matt16's Avatar
LOL good one
Old 07-15-2008, 09:02 AM
85toy's Avatar
sand.
Quick Reply: What have you found in your oil pan?
