What is this cable on my throttle body?
Old 09-19-2010, 07:43 PM
unclegussy's Avatar
No, its not the throttle cable. Just picked up this truck (1992 pickup with 22RE) second hand and I have good reason to believe the previous owner was a moron. Anyhow there is a loose cable coming from some sort of vacuum chamber thing on the driver side wheel well. In this picture (not my truck, found it on here somewhere) the cable is on top of the throttle body (green arrow) and my cable looks like it used to be in the same place, connected to the throttle actuator. What does this thing do, and should I hook it back up? The truck runs well, except it has a rough idle.
Old 09-19-2010, 07:55 PM
unclegussy's Avatar
Derp. I think its for cruise control.
Old 09-19-2010, 07:57 PM
Teuf's Avatar
No, I think that IS the throttle cable.
Old 09-19-2010, 08:06 PM
R.DesJardin's Avatar
cable
If it's not the throttle cable, or cruise control going to a vacumn diaphram, then its the TV cable going to the auto trans. Has to be one of those.
Old 09-19-2010, 09:18 PM
myyota's Avatar
If it goes over to the driver side wheel well and is connected there, then its part of the cruise control.
Old 09-19-2010, 10:14 PM
Teuf's Avatar
How about a better picture.
Old 09-19-2010, 10:22 PM
myyota's Avatar
The under hood picture he used is a picture of 4Crawlers 4Runner.
Old 09-19-2010, 10:56 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Cruise control. If you want it, hook it up.
Old 09-20-2010, 05:32 AM
norcal93's Avatar
Thats the throttle cable.
Old 09-20-2010, 06:15 AM
thook's Avatar
In the pic it is............but, the pic's not of his vehicle.
Old 09-20-2010, 06:22 AM
99blackSE's Avatar
Yeah, I'd bet it's an attempt at cruise control too. My SR5 doesn't have cruise but the bracket is there and everything to install it, just need all the gear to set it up.
Old 09-20-2010, 07:03 AM
thook's Avatar
Cruise control......
http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
Old 09-20-2010, 07:38 AM
unclegussy's Avatar
Yep, it is the cruise control cable. Wierd though, the truck didnt come with cruise control. It looks like someone tried to put CC in because there is a little janky looking (aftermarket?) CC box stuck to the dash. They must have gotten CC parts from another vehicle and tried to put it in. Seems like more work than its worth, although I should check it out to see if I can get it to work.
Old 09-20-2010, 10:23 AM
Teuf's Avatar
MMM I guess its not a TC....
Old 09-20-2010, 12:39 PM
iamsuperbleeder's Avatar
in the photo he posted, that IS the throttle cable and linkage
here's a similar setup in a Cressada
but what the OP is describing, that's the cable for the cruise control
OP, we need a pic of YOUR vehicle to be certain, but it does song like the cruise control cable, considering you described the cable as coming from "a vacuum canister"
Blamalam
03-12-2022 07:34 AM
jetpilot
08-15-2015 06:48 AM
mtc1105
08-04-2015 08:06 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: What is this cable on my throttle body?
