Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
What are all the parts included in the 4in bracket lifts?
hey guys.
i think that im actually ready to bolt everything up to my toyota tonight, and i just wanted to clarify a few things before i get greasy. this was in the pile of parts that i bought a while back... (some of you might remember the thread...) what is it, where does it go? ![]() ![]() ![]() and heres everything else. are their any other misc. brackets that im missing? ![]() ![]() ![]() i think ill only be using the crossmember on the right, the guy before me had to make the one on the left when he used both lifts together. (3.5in rancho and 4in procomp..) please let me know about the misterious crossmember asap! thanks, and wish me luck!
__________________
My MYSPACE - You know you want to request me. DD: '91 Toyota Pickup SR5 3.0L 4x4 5-Speed. Marlin Shifter Seat And Bushing, 31in. BFG ATs, Alum. Wheels, K&N.. 4in procomp and 3.5in rancho in the backyard. leaky valve covers!!!!!!!!!! '91 Toyota 4Runner SR5 3.0, auto, 31in. Multi Mile RVT's on AR Outlaw II's. no leaks. SOLD. <-- You Will Be Missed! 05.07.08 6:00pm. Broken: '95 Chevy S10 LS 2.2L I4 2x4 Auto, 31in. BFG M/T's on AR Outlaw II's, 3in Susp. Lift... Burnt up 3rd and 4th gear. Last edited by MIKEMOKAS : 07-24-2008 at 04:07 PM. |
| Sponsored Links |
#2 (permalink) |
Location: In the air, on the ground- hopefully makin your cellphone work better.
okay... you're missing some things... in particular the driver's side bushing and drop mount for the front differential housing. probably more, but my mind is pulling an OJ and didn't do it.
__________________
Knowledge is that thing people don't have that they hope others do so they can get out of trouble without having to learn anything themselves... It's time to re-claim 'green' as the color we deserve. Vote me as President, write-in candidate 2008.While you're at it, write-out EVERY Senator and Representative you can. join Yotatech chat at http://www.yotatech.com/misc.php?do=flashchat |
#3 (permalink) |
I don't see a second set of lower control arm mounting bolts - you need them to bolt the drop bracked to the old lower arm mounts.
__________________
#4 (permalink) |
I don't see the bolt used to bolt the existing steering knuckle to the drop brackets (where the old balljoint used to connect to the knuckle).
__________________
#5 (permalink) |
The one on the right go's to the front if you look at the stock one thats on there you will see the mount on the end is for your front third to bolt into.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift Kit custom 6" coils rear lock right #1620 Rear Aussie Locker #xd-27527 front 5.29's Front And Rear 35 x 12.5 x 15 B.F.Goodrich KO's Micky Thompson Classic II Wheels 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only Streached 5.5 gal. tanks 16" Ape Hangers 3" open primary "Three People Can Keep A Secret If Two Peolpe Are Dead" Benjamin Franklin |
#6 (permalink) |
you also need tapered sleeves for the spindle extensions.
brake line extension brackets. among a butt load of bolts that are missing
__________________
-Mike 1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket Soon to come: New wheels and tires, Sliders, CB. One Day: 3.4 swap! www.myspace.com/222948743 |
#7 (permalink) |
Brackets for dropping the sway bar and the bump stops are missing, as well as the LSPV extension (if you have the LSPV).
#8 (permalink) | ||
wow, thanks for all the replys!
i do have all of the bolts to do the job, and their all new. i still have to figure something out for the bumpstop extensions, and instead of dropping the sway bar im going to get longer bolts and sleeves, and leave the sway bar in the stock location. Quote:
Quote:
i went over their tonight and dropped off all of the lift parts and the box of bolts that i have. surgery begins at 2:00pm tomorrow! thanks for any help guys!!!
__________________
My MYSPACE - You know you want to request me. DD: '91 Toyota Pickup SR5 3.0L 4x4 5-Speed. Marlin Shifter Seat And Bushing, 31in. BFG ATs, Alum. Wheels, K&N.. 4in procomp and 3.5in rancho in the backyard. leaky valve covers!!!!!!!!!! '91 Toyota 4Runner SR5 3.0, auto, 31in. Multi Mile RVT's on AR Outlaw II's. no leaks. SOLD. <-- You Will Be Missed! 05.07.08 6:00pm. Broken: '95 Chevy S10 LS 2.2L I4 2x4 Auto, 31in. BFG M/T's on AR Outlaw II's, 3in Susp. Lift... Burnt up 3rd and 4th gear. |
#9 (permalink) |
The lsvp bracket is just a bracket that extends off the axle and pushes the lsvp trigger (whatever its called) up. Bracket should be the same amount as the lift in the rear.
Let me see if i can find a picture of the diff brackets.
__________________
#10 (permalink) |
Here is a link to the trailmaster installation instructions.
http://www.trailmastersuspension.com...ns/TP49_50.pdf Make sure you have those tapered sleeves! I had to order some, took a week
__________________
#11 (permalink) | |
Quote:
what is the exact job of the tapered sleeves? to center the origional hole that the balljoint goes into? dont have them either. bump stop, swaybar, and lspv brackets are going to be a cakewalk. the diff is only holding me up now. hopefully i can throw something together. thanks again! post up some advice/ ideas if anybody has any!
__________________
My MYSPACE - You know you want to request me. DD: '91 Toyota Pickup SR5 3.0L 4x4 5-Speed. Marlin Shifter Seat And Bushing, 31in. BFG ATs, Alum. Wheels, K&N.. 4in procomp and 3.5in rancho in the backyard. leaky valve covers!!!!!!!!!! '91 Toyota 4Runner SR5 3.0, auto, 31in. Multi Mile RVT's on AR Outlaw II's. no leaks. SOLD. <-- You Will Be Missed! 05.07.08 6:00pm. Broken: '95 Chevy S10 LS 2.2L I4 2x4 Auto, 31in. BFG M/T's on AR Outlaw II's, 3in Susp. Lift... Burnt up 3rd and 4th gear. Last edited by MIKEMOKAS : 07-24-2008 at 11:05 PM. |
#12 (permalink) |
turns out that theirs supposed to be 3 different front diff drop down brackets. i wonder exactly how long thos brackets are? because i could use the diff drop brackets out of my rancho kit.. i just dont know exactly how much i neeed to drop the diff. is it EXACTLY 4in? i think so.
![]() this would be the "center" one. ![]() and this would be the drivers side ![]() any thoughts? thanks!
__________________
My MYSPACE - You know you want to request me. DD: '91 Toyota Pickup SR5 3.0L 4x4 5-Speed. Marlin Shifter Seat And Bushing, 31in. BFG ATs, Alum. Wheels, K&N.. 4in procomp and 3.5in rancho in the backyard. leaky valve covers!!!!!!!!!! '91 Toyota 4Runner SR5 3.0, auto, 31in. Multi Mile RVT's on AR Outlaw II's. no leaks. SOLD. <-- You Will Be Missed! 05.07.08 6:00pm. Broken: '95 Chevy S10 LS 2.2L I4 2x4 Auto, 31in. BFG M/T's on AR Outlaw II's, 3in Susp. Lift... Burnt up 3rd and 4th gear. Last edited by MIKEMOKAS : 07-25-2008 at 09:01 AM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| are bracket lifts a good idea? | 88-surf | 86-95 Trucks & 4Runners | 8 | 10-11-2007 03:50 PM |
| WTB: 4in Lift Kit | MUDN4R | Items Wanted | 0 | 07-15-2007 09:22 AM |
| 90 toyota 4in lift w/ 33's | npreo1 | Offroad Tech | 16 | 06-22-2007 02:28 PM |
| Need pictures of Cheap IFS lifts. Not the parts but the truck! | JamesD | Offroad Tech | 23 | 11-10-2005 05:05 PM |
| Bracket lifts??? | 01Mossy Oak edition | Offroad Tech | 2 | 09-05-2004 05:47 PM |
