What Air Filter do you have in your 2nd Gen?
Old 06-12-2010, 07:30 AM
TidalVA's Avatar
Everybody needs one, what do you have?
Old 06-12-2010, 07:32 AM
conrad's Avatar
Napa Gold / Wix always does the trick for me.
Old 06-12-2010, 07:44 AM
UKMyers's Avatar
K&N drop in.. lots of people say they suck but it's usually because they don't oil them properly. They've been used in every application there is for decades..they must not suck that bad.. I have them in all my vehicles. It made a noticeable improvement in my Tundra.
Old 06-12-2010, 07:49 AM
crawyota's Avatar
Location: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
^^^^^^ x2
Old 06-12-2010, 08:55 AM
MaK92-4RnR's Avatar
^^^^ x3
Old 06-12-2010, 08:57 AM
camo31_10.50's Avatar
but you shouldn't have to oil an air filter to make it work properly.....
i'll be running a cheap rice burner filter on my 4runner...althought the K&N will stay on it for a while lol..i'll go ahead and use the rest of the filtercharger stuff too
Old 06-12-2010, 10:11 AM
bugs1961's Avatar
OEM air filter
Old 06-12-2010, 10:50 AM
2DoorRunner's Avatar
K to the N
Old 06-12-2010, 10:54 AM
iamsuperbleeder's Avatar
I ran several types with my 22re...
*stock paper style
*K&N drop in
*converted AFM to run 3" cone filter
The ONLY difference I ever noticed is that with K&N or the cone filter, you could hear the engine when you stepped on the throttle... I never noticed a power or MPG gain difference from running a stock style paper one...
In the end, I just said screw it and ran a stock style paper one
oh and the title's a little bland...
"What Air Filter do you have in your 2nd Gen? "
2nd gen what?
Old 06-12-2010, 11:08 AM
85toy's Avatar
i use the stock style paper filter, if you are using your truck offroad in a dusty climate you shouldnt use a k&n filter because it will let dirt get into your engine.
Old 06-12-2010, 11:22 AM
PirateMcgee's Avatar
I used to run K&N's till I noticed my oil was getting dirty way too fast (use OEM oil fitlers). Changed to a paper and the oil has stayed clean for much longer.
However, I did notice a power increase on specifically the 4runner (built engine) and slightly on the truck. It sucked going back to the stock setup! I'm looking at converting to a larger airbox from a 3vze or supra or something.
Old 06-12-2010, 11:29 AM
runneroffroad's Avatar
k&n drop in
Old 06-12-2010, 01:11 PM
85gijunk4x4's Avatar
a really old clogged up one, my truck wont run with it in...or out, so i keep it in ,unlatch the cover and rest it half over the filter and half off...beats spendin 20 bucks on a new one...jk
Old 06-12-2010, 02:29 PM
rattlewagon's Avatar
K&N. Came with the truck. Seems to work well but I have nothing to compare it to.
Old 06-13-2010, 12:38 PM
yotarover's Avatar
k&N works better than the cheap one it came with and i go splashing through mud everyday and think i have to hit every water hole in the street. G/F's reply to that: i knew you were going to do that so i rolled up my window before we even left the house
Old 06-13-2010, 10:06 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
I have an A/C Delco paper unit in the 2nd gen 4rnr/3.0. <<<How's that for spice, 'bleeder?
Old 06-13-2010, 10:20 PM
peow130's Avatar
Lol.. yes you should. On every dirtbike, fourwheeler, lawnmower, etc etc, on the market. The air filter is oiled. All it does is trap more particles.
Also: I run a cheap ass FRAM. Because i run a carb, and it doesnt matter what kind i put on mine because all it really sees is road anymore anyways.
Old 06-13-2010, 10:47 PM
awsumfn's Avatar
I run a K&N filter because I can wash (clean) the filter after each weekends use. I service the crap out of my Yota because I do not want any problems on trail. It's a funny thing.... why are most of the rigs broken on trail are neglected pieces of crap?
Old 06-14-2010, 07:16 AM
elblako91's Avatar
OEM Stock
Old 06-14-2010, 07:25 AM
UKMyers's Avatar
Ya it ticks me off when a trail gets clogged up and it's because of some stupid carnage that was totally preventable had the owner spent 10 minutes checking stuff BEFORE they went wheeling. I lay under my rig for an hour before every trail run checking U-bolt nuts, driveline bolts, diff fluid levels, steering arm bolts, ect.. more than once I found something that could of left me stranded later on.
Back on topic I run a K&N Filters on my Rotax that powers my AIRPLANE!
I pretty much trust my life to my engine most of the time since I'm always flying around in the mountains. The engine is a 582cc two cylinder 2 STROKE!!
And yes they get oiled... so does the Unifilter on my Motocross bike.
Quick Reply: What Air Filter do you have in your 2nd Gen?
