want to install some kill switches on my 91
#42
wire it so if you try to start it without flipping the switch it will not start, and it will lock the thief in the truck. If you wanna get real complex, put a code keypad in there
#43
#44
lmao ok i love the horn idea im going to run two switches, one will be a horn button right in plain sight right in that spot were you would have a AC button and a second one someplace on the floor it will kill the fuel pump. now if anyone can show me a pic or explain exactly were i splice and add my wires that would be awesome. Oyah you don't have to show me were you put your switches or anything just what wire to splice by the way a little toggle switch like something you would use on a go kart or something will be fine right? or should i run a fuse and a better switch? thanks guys
#45
SPDT toggle, rated 15 amps, interrupting the fuel pump this way:
- cut the wire to the fuel pump and connect the fuel pump side to one end of the switch and the other end (should be coming from the Circuit Opening Relay) to the center terminal of the switch... and connect the horn to the other end of the switch.
If the switch is set for the fuel pump to work, the truck starts. If the switch is set the other way, the horn goes off when the thief tries to crank it over or tries bump starting it and the AFM turns the COR on.
#46
thanks dude thats an awesome way to do it i am going to try and do this sometime this week, i just need to find the wire i need to splice and then im golden
#47
there are 2 black wires going in 2 ignition switch one has a yellow or a whit stripe eather of those you can put a switch in that line and not allow starting but i use a battery switch and a starter switch batt switch is easy find a marine store near by u and ask 4 a battery switch they work than the other is just for ur pice of mind i have had a truck stolen with kill switch push button start and fuel cut of switch so you can only do so much but.. i did find this
Pedal Jack Anti-Theft Device
The ultimate anti-theft device for your car.
Steering wheels can be cut to get around an anti-theft device, but your pedals are virtually unbreakable. Pedal Jack attaches to your brake pedal to give you unbeatable security. It's constructed of heavy duty, electrically heat-treated tempered steel so it's saw-proof and cannot be fractured by freon gas. The patented locking system's tempered steel plate makes it drill-proof. And the highly-visible yellow handle deters thieves from even attempting to steal your vehicle. Pedal Jack is fully adjustable to fit virtually all automatic trasmission-equipped cars, SUVs, vans and light trucks.
they have a similer 1 at pepboys i havent got past it yet
#53
ok you mean to the left of the seat under that plastic molding at the door jam? i have no carpet in my truck so it will be easy to find then? thanks
#56
yeah left of seat under plastic and easyist way is to look at wire coming of pump than looking at wire in cab but mine is black and white i have an inline switch
#59
of corse i am mostly joking but this could work, get a long whisker switch (metal)and wire it to the horn, rest the whisker portion on the cat, and solid mount the switch housing to the frame out of site and when the converter is lowered down, the horn honks. i realize by this point the converter is all ready stolen but at least the thief will poo himself and maybe hit his head trying to escape. LOL!
