Vacuum line - where does it go?
Old 06-03-2006, 07:06 PM
davido's Avatar
I am trying to resolve a pulsing idle problem in my son's 91 4-Runner 3VZE, which seems to be due to an air leak.
I've found a vacuum hose which is disconnected (plastic ferrule on end has broken off) but I can't see where it came from, as it seems to be somewhere at the rear of the engine and my workshop manual is worse than useless.
Hopefully one of you gentlemen will be able to help!
It is the line from the Purge outlet on the fuel canister, as shown in the pic.
Old 06-03-2006, 07:25 PM
Chuki's Avatar
Check under the upper plenum for maybe any vacum ports open. Hard to see but they're there. It also might attach to the water bypass thats bolted onto the lower intake.
Thats a charcoal canister though? My charcoal canister is on the passenger side. Or does that have something to do with the cruise control?
Your picture shows components that are on the oppisite side of mine.
I dunno maybe someone else can chime in here!
Old 06-03-2006, 07:42 PM
ChickenLover's Avatar
His steering wheel is on the wrong side (mentioning that would have been helpful). The hose from the canister plugs into a port on the coolant bypass outlet. It plugs into the top of the blue fitting (TVV).
Old 06-03-2006, 08:14 PM
snap-on's Avatar
nice catch on the right hand drive
Old 06-04-2006, 04:22 AM
davido's Avatar
Sorry fellas, I neglected to say that we're in Oz and drive on the proper side of the road! I meant to put that in the original post as the photo could be confusing otherwise. (I'd better get my location details entered.)
The photo will be a help - thanks.
raptor510
08-19-2015 02:15 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: Vacuum line - where does it go?
