Old 02-10-2016, 09:27 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Ultimate 2wd Rear axle upgrade using all factory Toyota parts!!
Old 10-28-2013, 10:09 AM
250000_yota's Avatar
Low4life, you've got me baffled. Honestly nothing you listed there would cause your highway cruising rpms to change. From the flywheel back is fixed ratios. In gear, the ratios never change, so you shouldn't see any rpm difference from one mod to the next.
Did you change tire size or rim size when you added all that stuff from lc? Is the clutch in good condition and adjusted properly?
Old 10-28-2013, 11:12 AM
redbayredneck's Avatar
low4life, when you say that it cruises at a higher RPM range, do you mean that its going the same speed you used to cruise at just higher RPMs or that it cruises better at higher speeds than it used to?
Also, to osv; I've abused my Yota axles pretty bad for non-reinforced axles and haven't managed to bend one *knock on wood*
Old 10-28-2013, 07:49 PM
totally a bro
Staff
vital22re's Avatar
everyone is pretty and all your dresses look nice. Thread cleaned up. If you can't play nice, ban hammer starts swinging.
Old 11-08-2013, 02:10 PM
sitnlow4life's Avatar
OK so check this out
I recently reinstalled a cat on the truck to get rid of some of the drone involved with running no cat .
Now the truck likes to cruise in 5th at like 2200-2500 again.
Weird huh ?
Old 05-11-2016, 03:12 PM
  #25
Baja4Runz n Tacos's Avatar
rear diff 2wd locker
anyone knows who to contact to upgrade a 2wd 93 4runner rearend with a diff lock option, this a lighter project offroader that sports a front X9 9000lb 12v. winch. Gracias amigos !
Old 05-11-2016, 06:37 PM
  #26
Gadgedizzle's Avatar
If its a 7.5" (bolt at 12'o clock on pumpkin) then you're up ˟˟˟˟˟ creek.
If its an 8" you need to start looking at 4wd shops. Like 4wheelparts.com or something. However, if you didn't notice, this thread is related to 2wd supra 8" diff's. Not the best place to ask about 4wd crap.
6th Gear
19
12-10-2019 07:31 AM
Csefiroth0
06-30-2015 02:19 PM
Niameyrider
06-25-2015 05:50 AM
Chooch
06-19-2015 03:05 PM
Juan Manzione
06-10-2002 04:12 AM
Quick Reply: Ultimate 2wd Rear axle upgrade using all factory Toyota parts!!
