turn signal relay
Old 04-09-2012, 05:18 PM
pperry71's Avatar
turn signal relay
where is the turn signal flasher/relay on a 93 4runner ?. i have the dash apart and still dont see it.
Old 04-09-2012, 05:36 PM
Hadmatt54's Avatar
According to the diagram it is left of the steering column, up under the dash, just below the combination meter.
Old 04-09-2012, 05:53 PM
pperry71's Avatar
i found the 4-way flasher at that spot. but not the turn signal.
Old 04-10-2012, 07:34 AM
pperry71's Avatar
check on my 90 truck and the 4-ways and turn sigals use the same flasher
Old 04-10-2012, 07:41 AM
Outsane's Avatar
isn't the 4-way the same as the turn signal?
Old 04-10-2012, 08:08 AM
pperry71's Avatar
yep, thats what i found on my 90. just got the turn signals working. checked all fuse's with test light and they showed good . went ahead and replaced the turn signal fuse and now they work .
Old 04-10-2012, 08:16 AM
nv4runner's Avatar
Alldata shows the same flasher for both 4-way and turn signal, as does the wiring diagram. Why are you pulling it anyway? Turn signals not working? If the 4-ways work but turn still doesn't, then the flasher isn't your problem. Next thing to look at would be the fuse, bulbs, and the switch.
Edit: Just saw your new post. Keep a few extra fuses handy. If it blew a fuse once it is likely to do it again until the cause is found. Glad you got it working and good luck!
Old 04-10-2012, 08:30 AM
MudHippy's Avatar
where is the turn signal relay on a 93 4runner?
Technically, it's part of the integration relay. Which is behind the driver's side kick panel, as shown here...http://personal.utulsa.edu/~nathan-b.../4lighting.pdf
okamikai
04-30-2018 10:19 PM
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
moonpie
07-31-2015 11:58 PM
PopsDad1
07-30-2015 02:21 PM
Quick Reply: turn signal relay
