Transmission mount smoked? and questions..
Old 10-08-2010, 02:12 PM
dhall50's Avatar
Originally Posted by yotaman90
Any updates dhall50?
Sorry nope. The one I ordered was wrong so I plan to replace it with some a spare that a friend has. This is all on standby because I just became a dad on Wednesday.
Old 12-21-2010, 03:18 PM
milowilli's Avatar
What is the big bolt for in the center of the mount? Besides the bolt are there any other pieces that go with the bolt?..Washer or spacer maybe? I have a mount for an Auto trans (22RE) and am not sure if i should have more than 2 pieces..the mount and the big center bolt.
Old 01-09-2011, 09:26 PM
yotaman90's Avatar
Did you change the mount yet?
Old 01-10-2011, 09:08 AM
dhall50's Avatar
Sorry, baby has kept me pretty busy. I replaced a mount with an equally old one from my friends spare pile and it is still as flexible as the original was. When I have enough money to blow I will replace the tranny and engine mounts. Until then I have to deal with it.
Old 01-12-2011, 12:27 PM
  #25
Ilovemountains's Avatar
My 88 3.0 auto 4x4 is doing the same thing, my transfer case mount is broke, I can grab the drive shaft and push the whole thing up, you can see the rubber blocks are totally broke, which Im sure is causing the driveline to be out of alignment under load. I got a Beck Arnley on Amazon for $50 shipped, the part number is Beck Arnley 104-1387. Make sure you buy an Automatic mount, I found out the hard way that the manual mounts do not fit, if this is your issue! It could also be a bad U joint, I bought OEM Matsuba with grease fittings from these guys for under $20 each, made a HUGE difference.
https://www.4wdfactory.com/store/pro...t-U%252dJoints
If you had the drive shaft apart for any reason it could be out of phase wich will cause a nasty vibration too, my 82 Trekker had this issue when I bought it.. Take a look at this page for info:
http://www.4x4wire.com/toyota/tech/driveline/
chuckross1957
06-28-2019 10:19 PM
mskalmus
05-28-2017 07:51 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Tigbucket
07-30-2015 07:29 PM
Jonny246
07-24-2015 12:37 PM
Quick Reply: Transmission mount smoked? and questions..
