Torque Converter install
Old 11-23-2010, 10:29 PM
Swim's Avatar
I'm a manual guy... this auto is really driving me nuts.
So, I pulled my old engine (build up thread coming) and a new 3vze ready to get dropped in. I need to pull off the torque converter and the flywheel and attach them to the new engine.
Question:
Can I just unbolt the torque converter from the flywheel, then unbolt the flywheel from the engine, and then bolt it all back up to the new engine?
Is there something I'm missing?
Old 11-24-2010, 09:03 AM
Swim's Avatar
Hmm... that makes sense. I'm assuming the shims are there to keep everything balanced.
Ok, so when you drop the engine back in, you manage to thread those bolts between the TC and the FP in that gap about a half inch wide? Then slide the engine the rest of the way in, and bolt the engine to the tranny?
Thanks for the help
Old 11-24-2010, 10:34 AM
Staff
DeathCougar's Avatar
One BIG THING
Make 100% sure the torque converter is seated in the trans PROPERLY before trying to bolt them together. I can't tell you the number of front pumps I have seen broken by people installing the converter wrong.
Once its filled up with fluid, you need to double seat the converter. That is, spin it while pushing in and it will pop down twice (ergo double seated). If you aren't sure, take it back out and do it over again. Better to 100% sure than break that pump.
Old 11-24-2010, 09:07 PM
Swim's Avatar
Ok, I put it in the trans. I'm pretty sure it clicked 2 times. Is this a loud click, or is it more of a feel type thing?
Old 11-26-2010, 10:41 PM
Swim's Avatar
On another note.... I didn't find any shims.
Old 11-30-2010, 04:13 PM
4runnerx3's Avatar
Found these searching through my photobucket today.
Old 11-30-2010, 04:23 PM
Kiroshu's Avatar
Never supose to take the touque converter out with the engine as it can damage the transmission and converter.
Always unbolt the converter from engine before removal of engine and or trans.
Old 12-01-2010, 10:38 PM
Swim's Avatar
Well, I've got the engine almost back in. For some reason I've managed to get all the bolts into the tranny.... except the 3 short ones at the bottom. The brackets don't seem to line up. Time to loosen the brackets and try again.
Buddy snapped my Dizzy in half... had to fight to get that out. New one has been located and purchased. Hopefully I'll have this back together tomorrow.
Old 03-24-2022, 10:21 AM
Micah12345's Avatar
Is it toast?
Originally Posted by DeathCougar
One BIG THING
I definitely did not install my torque converter correctly, i heard the first click and I thought it had done a second. Didn’t realize till after I got the engine together. How much of a chance is it that I destroyed that pump?
brpeppers
09-10-2010 07:05 AM
ethanp123
11-11-2009 02:54 PM
jaysTOY
01-25-2007 09:00 PM
hellonweels89
09-05-2006 09:42 PM
Quick Reply: Torque Converter install
