throwout bearing replacement
Old 03-25-2012, 12:37 PM
meswoleshane's Avatar
One version is, the other is a entire assembly.
http://www.marlincrawler.com/clutch/...g-1981-89-4cyl
http://www.marlincrawler.com/clutch/...g-1990-95-4cyl
I know the years are different but my 87 4Runner and another 88 ext. cab I had both had the later type of bearing. Neither of them had ever been changed out to the best of my knowledge...
Old 03-25-2012, 04:27 PM
slacker's Avatar
hes talkin /86 .. lets not confuse the original post !!
no question .. it is a hub with a bearing pressed on
Old 03-25-2012, 07:07 PM
2012MongolRally's Avatar
Thanks for those links shane, that is exactly what I had in my hands when I was putting in the transmission for my 1993 pickup (I know I have a different model than the guy that started the post, sorry but I didn't want to start another thread since the topic was so related). Next time I will remember that two different bearings existed and there was a switch over from one style to another in 1989. Thanks
Old 03-26-2012, 12:18 PM
I understood the original post... I'm saying there are two different designs and I have found the newer style in older trucks where it shouldn't be. The part is COMPLETELY different and does not press on. I even pryed open the housing holding the bearing to compare the two bearings (the one for a 86-88 to the one actually on my w56b in my 87') and they were NOT the same. I went back and found the part for the newer trucks was exactly what was in my truck. I have found this on 3 of my own trucks and they were original.
When I pull the transmission on my 87' 4Runner to replace the bearings in a few weeks I am going to replace the clutch. I will post pics of what comes in the kit vs what is actually in my truck.
Old 03-26-2012, 07:05 PM
  #25
Cool, I look forward to seeing those pictures. I used the old throwout bearing, but I am keeping a going to get a backup old style throwout and a new style throwout bearing just as backup. I think your pictures of the clutch install will help clear up the situation though, thanks.
Old 04-01-2012, 06:54 PM
  #26
Here is the throw out bearing that was in my truck (1987 4Runner) next to what comes in the kit for a 1987. I have a W56B transmission. The part that came out of my truck is what is on the newer trucks. I have seen this on a few other trucks as well.
I wanted to share this with everyone so if anyone else runs into this issue they can find something about it.
Old 03-25-2018, 06:54 PM
  #27
My71fj40's Avatar
Thats it
Thanks that is exactly my problem, the kit came with bearing only, had to go buy the bearing with housing for my 88 4runner
bigjstang
08-25-2021 12:41 AM
jasonty
41
12-23-2018 01:00 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: throwout bearing replacement
