Throttle plate setting at idle, 1994 pickup 22RE
Old 03-22-2012, 02:02 PM
bigpaw's Avatar
Brother messed with TPS/throttle stop/dash pot set screws trying to "adjust idle" instead of turning the idle bypass screw. I have noticed there is no method for re-setting the correct throttle plate opening at idle in the factory repair manual, but that in the MFI System--Service Specifications section there is a spec that says, Throttle Body, Throttle valve fully closed angle, 6 degrees.
Can anyone verify if this means: Back off the throttle stop screw till throttle valve bottoms-out, mark the angle as zero degrees, and then set the stop screw when the angle reaches 6 degrees?
Old 03-22-2012, 02:15 PM
BMcEL's Avatar
Back the stop out until the valve is fully closed, then slowly turn the stop back in until it is about to start opening the valve. At that point, give it another 1/4 turn and lock it down.
Old 03-29-2012, 07:25 PM
bigpaw's Avatar
What does the 6 degrees refer to?
Old 03-29-2012, 10:14 PM
TylerH's Avatar
It should have a paint mark were it was marked when set at the factory. Get that back to where it was. And it should be really really close to perfect.
Old 03-30-2012, 01:15 PM
bigpaw's Avatar
I thought I could but there is no paint on the screw or nut anymore.
Old 03-30-2012, 01:53 PM
BMcEL's Avatar
It's a pretty easy adjustment...I actually had to do this recently. Follow my instructions above or 4crawler's:
Originally Posted by 4crawler
The stop screw is set so that the throttle plate is fully closed inside the throttle body, then it is turned in to contact the throttle linkage and then 1/4 turn more before tightening the jam nut to lock it in place. This is done so that the throttle plate is held just barely off fully close to prevent it from sticking inside the throttle body.
JF9243176
10-08-2017 04:21 AM
94 Newbie
07-06-2015 04:23 AM
JF9243176
06-24-2015 04:53 AM
94hiluxZE
06-22-2015 10:42 AM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: Throttle plate setting at idle, 1994 pickup 22RE
