Thermostat bypass hose
Old 12-07-2012, 02:10 PM
Camaro1976's Avatar
My truck started spraying coolant on the ground so I looked and it seemed like the previous owner capped off the outlet on the thermostat housing with a vacuum cap that burst. After some research I believe this is where the thermo bypass hose should be. I looked and I have no idea where the hose would connect to if I had it…. Right now I have it capped off again with some 1/2" hose, a barb, and a pipe cap.
My question is where would the bypass hose connect if I had it? I tried going through the fsm and schematics online and couldn't find anything on it.
Also what is going on if I have it capped off?
Old 12-07-2012, 04:05 PM
Philbert's Avatar
Year, model and motor info might get you a faster response
I don't know, just suggesting an idea
Good luck
Old 12-07-2012, 04:10 PM
j2the-e's Avatar
Not sure I'm familiar with any outlets on the tstat housing other than the radiator hose. 3.0 V6? Maybe you're referring to the hose off the water pump for the oil cooler?
Old 12-07-2012, 04:18 PM
Camaro1976's Avatar
Sorry, yeah it's a 94 truck with a 3.0.
It is definitely off the thermostat housing that the lower radiator hose goes into. It might be directly into the block behind the housing, it's hard to tell with a flashlight. I have never seen anything like it, but I'm not that familiar with yotas
Old 12-07-2012, 05:54 PM
j2the-e's Avatar
That tube is part of the water pump. Hose should run under the oil filter to the cooler which mounts to the block behind the filter. Probably capped on the other end too.
Old 12-07-2012, 06:18 PM
2toys's Avatar
its the for sure the hose from the water pump to the oil cooler could be that someone ordered the wrong water pump (if you don't have the oil cooler) and just said f##k it. if that's the case then throw an oil cooler on it.
Old 12-08-2012, 03:29 AM
Pat8942's Avatar
This might help
Old 12-09-2012, 03:54 AM
TNRabbit's Avatar
Originally Posted by Pat8942
This might help
Yep. If you don't have an oil cooler, the PO bought the wrong water pump~
urabus
11-10-2015 07:38 PM
LotOMiles
09-14-2015 11:45 PM
elaketiger
09-14-2015 09:58 AM
noahstancik
09-10-2015 10:47 AM
--Oz--
09-06-2015 01:06 AM
Quick Reply: Thermostat bypass hose
