tacoma 6 speed into a 94 pickup
Old 06-12-2009, 03:27 AM
KelleyC's Avatar
*Note, the short reply being go find a 6 speed, unbolt the bellhousing, see if a R150/R151 bellhousing will bolt up. How about the input shaft and will it fit the pilot bearing and not be too long?
Yes or No?
Now, if yes, see if a right drop transfercase will bolt up or if you need the adapter. Call Marlin Crawler, see if there's an adapter (since I know Inchworm makes one, and Marlin makes far superior stuff) and if not can they make one you can use a geared case with? it's all really simple as far as the case drop goes as they already have all their adapters in CAD format and it's somewhat simple to do modifications and changes.
Yes or No?
If yes, order up then figure out driveshaft lengths and angles.
Last edited by KelleyC; 06-12-2009 at 03:43 AM. Reason: Clarifying the last bit of tech :)
Old 06-12-2009, 02:08 PM
TNRabbit's Avatar
The R150F has a 160 mm input shaft; if I'm not mistaken, the R151, R154 & I think W58 have the longer 190 mm input shaft.
Old 06-12-2009, 02:25 PM
scuba's Avatar
Wow great post(s) Kelley..
Oh and spacey boy, I wasnt trying to talk the dude out of it, I was just stating its not going to be a cheap bolt in swap.
Old 06-12-2009, 10:44 PM
KelleyC's Avatar
Thanks, you never know the people behind the screen and sometimes they can surprise you with good info and experience.
Old 06-13-2009, 08:53 AM
  #25
OltorfTD's Avatar
i wasn't under the impression that this would be a "cheap bolt in swap." right now i'm just trying to decide what i want to with the truck. I'm trying to decide if I want to swap in a 3.4, the whole 4.0 drivetrain, or nothing, and buy a newer tacoma in a few years.
thanks for the info, kellyC. i'll contact marlin crawler, or just wait until some more info comes out about a 4.0 swap. i'm a decent mechanic, but i'm no engineer. i dno't think i have the skills to figure out how to swap the whole drivetrain.
Old 06-13-2009, 09:03 AM
  #26
JonnyBoy's Avatar
Newer R150's also have the longer input shaft(such as the 150's behind the 3.4)
Old 06-13-2009, 09:04 AM
  #27
toyota4x4907's Avatar
I bet the R150F got made fun of in the locker room a lot ....
Old 06-13-2009, 10:09 AM
  #28
881stGenRunner's Avatar
this is a really cool thread, im definately going to subscribe to this one to see if anything becomes of it.
To the OP good luck man, i really hope this can get pulled off!
Old 06-13-2009, 04:21 PM
  #29
KelleyC's Avatar
No worries, glad to be able to contribute and help.
FWIW a S/C'd 3.4 and R150 w/ a gear case adapter conversion is really nice. A hopped up 3.0 w/ Ceramic 505 Thorley's into a SuperCat and a Flowmaster (*bit loud) with full 2.5" tailpipe to the rear bumper will also do pretty well. Just stay on top of your cooling and have a great tech do the heads and gaskets.
I'll see if I can get you a video of that if you like.
Old 02-05-2012, 04:56 PM
  #30
Countryhick's Avatar
Ive done plenty of research on this only way to do this would be having a 5vz swap into a truck and do a sas with drivers side drop dana 44 or 60. or tacoma rock assault
Old 02-05-2012, 05:12 PM
  #31
peow130's Avatar
Or read KelleyC's first post in this thread, and stop being a thread-o-philiac and bringing up old threads.
Old 02-05-2012, 05:53 PM
  #32
called searching 6speed swaps. lol Dont be a Smart A.
bigjstang
08-25-2021 12:41 AM
God's Bounty Hunter
07-08-2015 12:54 PM
HRDC0R19
07-05-2015 06:43 PM
zd92655
07-05-2015 04:25 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: tacoma 6 speed into a 94 pickup
