strange engine noise
Old 02-06-2012, 03:41 PM
mcgunn74's Avatar
Heres the low down. 1988 4runner 4x4 140,000 miles, 3.0 v6. Recently done alt, coil, plugs and wires, distributor cap and rotor, fuel filter, oil change 10-40, seafoam treatment in gas and crankcase(100 miles before oil change), coolant flush and fill.
Heres the issue, the engine had a small tick I assumed to be a sticky lifter, but now it sounds more like a slapping loose part. I used my trusty dowel(poor mans stethoscope) and found most of the noise coming from the drivers side of the motor near the distributor, timing cover. I have also developed a kind of loping sound to the motor and occasionally erratic idle at start up. any ideas?
Old 02-06-2012, 03:44 PM
mcgunn74's Avatar
forgot to mention Im losing some coolant but no visible leaks , wet floor boards, or steamed windshield.
Old 02-06-2012, 04:09 PM
93toyrunner2's Avatar
Use your stethoscope and put it on the fuel pressure regulator, top drivers side front fuel rail. The regulator can make a lot of noise.
Old 02-06-2012, 04:16 PM
"G"
"G"'s Avatar
Sounds like a distributor problem, I would check for any slack.
Old 02-06-2012, 04:25 PM
mcgunn74's Avatar
Well I just check that and ...thats not it. However, the noise is louder slightly, and seems to be coming from the distributor. Could this be a timing issue, something related to the new cap and rotor( napa), or do i need a new dizzy?
Old 02-06-2012, 04:27 PM
mcgunn74's Avatar
slack?
Old 02-08-2012, 03:22 PM
mcgunn74's Avatar
Still need help! No loss of power or mpg drop, but the motor sounds like its going to come apart when idling. Can a distributor make this much noise? Something else? All ideas and help welcome.
BushPig
10-29-2022 06:26 AM
razorman8669
07-12-2015 12:13 PM
Jonny246
07-12-2015 04:51 AM
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: strange engine noise
