still overheating after new radiator
Old 08-07-2009, 06:51 PM
yoder519's Avatar
well before i put my 2inch bodylift on, my truck overheted some, not on the red or nothin but past halfway. so i put a new radiator in it while i was doin the bodylift now its doin it mroe often. before the BL, i cud flip the heat on high and it would drop. now when i flip the heat it does nothin. i seen a post i think deathcougar posted on another thread like this but mine isnt overhating like the other guys was. i think it was gary9096 or sumn. any iders?
edit- i guess the title should be still overheating after new radiator. whooooops
Old 08-07-2009, 06:55 PM
Elton's Avatar
is the fan shroud still intact ?
Old 08-07-2009, 06:57 PM
mattaway's Avatar
are you sure you burped all the air out of the system? let it run in the driveway for awhile with the rad. cap off, rev it up a little once in awhile, add coolant as needed... it might take 5 minutes, it might take 30 minutes.
Old 08-07-2009, 07:20 PM
yoder519's Avatar
yea fan shroud is still intact.... but... i for got to bolt it back up before i started it and i turned it off real quick and it chipped the fan around the edge maybe a quarter inch if that. that wouldnt be the problem would it? and mattaway i did that righ twhen i put it on but jsut for a minute or two. ill trya it again. thanks fellas
Old 08-07-2009, 07:33 PM
myyota's Avatar
Have you tryed a new thermostat ?.
Old 08-07-2009, 07:39 PM
Elton's Avatar
yes and get the correct one from the dealer
Old 08-08-2009, 07:17 AM
Jay351's Avatar
Did you install radiator drop brackets for the body lift? If not then thats your problem, not enough airflow.
Old 08-08-2009, 07:18 AM
yoder519's Avatar
i pu ta new thermomstat onit in feb i think. its not from the dealer its from advanced auto
Old 08-08-2009, 07:19 AM
yoder519's Avatar
yis sir radiator drop brackets are there
Old 08-08-2009, 07:22 AM
Jay351's Avatar
Are you 100000x sure you got all the air out of the cooling system?
When does it overheat, in traffic or on the hwy?
Old 08-08-2009, 07:29 AM
yoder519's Avatar
traffic... its funny but it has always seamed to run cooler on the interstate.
Old 08-08-2009, 07:35 AM
Jay351's Avatar
Fan shroud got one? and its not just a peice of one right
Fan clutch, I would check this out. Get the truck to its normal temp and stop the motor and have somebody watch the fan. If it spins more then a revolution or so then its bad.
The fan does all the cooling in the city, it pulls the air across the rad. Stands to reason why it would get cool once you get moving.
Old 08-08-2009, 06:43 PM
yoder519's Avatar
thanks jay! yep fan shroud is in one piece but my fan is chipped a littel around the edges. i thought about the fan clutch ill check that out.
Old 08-10-2009, 07:35 AM
yoder519's Avatar
well... i drove it to work yesterday... it started overheating really bad. right at the red mark. then my truck kept turning off whiel i was driving it. i bout died goin around a curve when it cut off. but the funny thing is... it ran like a top on the way hoem and didn teven think about overheating
Old 08-10-2009, 08:04 AM
crafthorse's Avatar
I would replace the Thermostat and the fan clutch. Thermos can stick even when new, get one from Toy, or NAPA.
Old 08-10-2009, 09:08 AM
highway's Avatar
is the water pump circulating enough ?
Old 08-10-2009, 09:11 AM
yoder519's Avatar
dunno. the water pump is about 10 months old. what would make the truck die liek that? overheating?
Old 08-10-2009, 09:13 AM
yoder519's Avatar
yea im gonna replace the thermostat since its not to expensive. i would assume the fan clutches aint that expensive either. do i have to get it from the stealership?
Old 08-10-2009, 09:22 AM
Elton's Avatar
just where did you buy this water pump
Old 08-10-2009, 09:31 AM
yoder519's Avatar
im no tsure i had my truck in the shop and the garage ordered i tand put it on
Quick Reply: still overheating after new radiator
