Speedometer drops below zero, always 10mph slow
Old 10-25-2013, 05:42 PM
AshenCrow's Avatar
Did some searching and all I could find was fixing speedo readings for different size tires/gears. Also found a ton of broken speedos, but nothing like my problem.
When stopped, my speedometer sits below zero, pegged down to around -10mph if such a mark existed. When I'm doing 15mph according to the dash, GPS lateral speed and radar read 25 mph. Reading 35 at an actual 45mph. Speedometer at 60mph means truck is moving 70mph. You get the point. It's off by 10mph at EVERY speed, it's not a ratio thing. I assumed it was because of tire size, but if that were the case it would be off by twice as much at 70mph compared to 35mph. Also, I'm running 265/70/R16s which are comparable to the stock 31" tires listed inside the door sill.
Is there any way to take apart the dash and manually re-zero the needle? My friend said to leave it in case I get pulled over for speeding but not only do I not really speed, but that feels sleazy. I accept responsibility for what I do and I want my speedometer to be accurate in case some one else is driving.
Old 10-25-2013, 06:06 PM
BigBluePile's Avatar
What gear ratio do you have?
Old 10-25-2013, 06:58 PM
AshenCrow's Avatar
Don't know yet, but it is stock. As I said before, this would not have anything to do with the gear ratio. If it were the gear ratio and I were off by 10mph at 70, I would be off by 5mph at 35. It even works exactly as it should when the needle is below zero, when I'm at 1-10mph... it's just below the scale. As far as I can tell the needle is just turned to the left by a few degrees, equal to around 10 mph. Can that needle be adjusted manually if I open my cluster?
Old 10-27-2013, 09:29 AM
Ok......
Old 10-27-2013, 09:55 AM
HighLux's Avatar
a 265/70/16 is about 32" problem solved.
Old 10-27-2013, 10:02 AM
93Xtra-Cab's Avatar
No, a 1" tire diameter increase shouldn't create a 10 mph difference...
Old 10-27-2013, 10:11 AM
Stevesk88's Avatar
Had a camero that read like yours did. But that was because the speedo only went to 120 and the car had done way over that on the strip. Same problem? haha
Old 10-27-2013, 10:25 AM
AshenCrow's Avatar
I'm really not trying to be an ass, I promise, but I've dealt with tire size differences on several cars before with cable and electronic speedometers and it never did this. Please don't take offense to my wording, I'm not being mean and I appreciate you trying to help.
Actually, they're about 31", nearly equal to the stock 31x10.5s that came on my 4R from the factory. Two sources confirm this. Circumference is the important stat here.
Let's look at this empirically. First is stock vs my tire, speedo vs calculated actual vs GPS-verified actual. I am ALWAYS 10mph over. Not a percentage of speed difference, but a constant difference at every speed. I actually tested this at 15, 25, 35, 55, 60, and 70mph with two GPS devices to account for error because it seemed so strange.
Here is what it would look like if I had put bigger tires on a truck that had smaller tires from the factory. The difference in circumference would lead to a percentage difference in speed. I.E. the example tires are 9.2% bigger in circumference, so 9.2% extra of 35mph is 38.22mph and 9.2% extra of 70mph is 76.44mph. That's a 3.22mph bigger difference at 70mph vs 30mph. Mine is 10 over at 30 and 10 over at 70.
Do you guys understand why I have ruled out gear and tire sizes now? I feel like I really beat a dead horse but I wanted to be clear from every angle. I really believe my cluster just needs to be manually adjusted but I didn't want to tear into it unless some one knew it could be done... that's really all I was asking. =\
Old 10-27-2013, 10:43 AM
Hmmmm.....so you says it's not the gears.....
Not sure about adjusting the speedo but try swapping in s difftent cluster?
Old 10-27-2013, 10:48 AM
AshenCrow's Avatar
Thought about it, but from what I've seen on the board it seems like my SR5 cluster is highly sought after and it would be wise to attempt to fix it first. What do they usually go for, anyway?
Old 10-27-2013, 11:25 AM
nothingbetter's Avatar
from what I remember, the needle pulls off and can be pushed back on at any position. its a friction fit...if I recall correctly. And it its not, bend it.
The following users liked this post:
Jimkola (02-16-2021)
Old 10-27-2013, 11:27 AM
AshenCrow's Avatar
Bend a plastic needle 15-20 degrees in an arc? Sounds like a good way to break it, lol. I will try to pop it off, thank you nothingbetter. =)
Old 10-27-2013, 02:27 PM
MudHippy's Avatar
Don't count on it popping right off. It's going to be on there pretty tight. You've got a fairly high chance of breaking something doing that too, if you're not super careful. But you can always replace just the speedo/odo unit. They're only about 150 bucks or so new. And yes, a used combo meter(with a good used speedo/odo in it) is going to run you way less(usually). I see them going for as low as $50. Sometimes a little less, sometimes 3x as much. Check ebay and/or car-part.com.
I bet that's pretty common. I did the same thing to the speedo in the Camaro I used to have(except I did that on a highway, not a strip). But, from what I can remember, the speedo in mine only went to 90. And once I pushed it about 40 mph past that, it read around 15 mph low. 90 mph speedo in a Z28...ummm o.k., sure. Like that's even close to high enough. WTF?
Old 10-27-2013, 07:03 PM
RJR
RJR's Avatar
Maybe if you backed up at about 30 mph it would bend the needle back the other way! :-)
(Sorry, couldn't resist...)
Old 09-08-2014, 09:18 AM
ChzSoda's Avatar
I'm having the same issue in my 91 PU after replacing the speedometer cable. It's not a gearing issue because it read correctly before the cable broke. Now it sits at -10 when stopped.
Old 09-08-2014, 11:02 AM
mct75's Avatar
Use a fork to pry the needle off. Easy.
Old 09-08-2014, 03:40 PM
Badger62811's Avatar
You guys are awesome. The extent the OP has had to explain himself. And the humorous comments. My personal favorite is doing 30 in reverse.
Old 09-09-2014, 03:41 AM
mct75's Avatar
If OP would remove his magical gears that produce a 10 MPH offset at every speed, this wouldn't be an issue!
Old 05-09-2017, 05:11 AM
rrehuram's Avatar
Is still this top is not closed
Old 02-15-2021, 09:59 AM
OneInNone's Avatar
Same issue
Hey all, i am having the exact same issue and i was hoping that someone would also know the fix. I too have over sized tires and i was hoping that that may be the cause.
Quick Reply: Speedometer drops below zero, always 10mph slow
