Solenoid Location on transmission
Old 08-06-2010, 10:08 AM
95runner67's Avatar
When it comes to working on Toyotas I have no idea on where things are. My 67 mustang has decided to become a pain in my butt and not want to work correctly. So I'm starting to drive the old 4runner again. However I'm not getting the trouble code 62 for the O/D and I believe 74 for check engine light. So I need to know where the #1 solenoid is on the automatic tranny of a 95 4runner 4WD.
The check engine light was for failed EGR I believe, so I might look into getting that taken care of as well.
Old 08-06-2010, 10:24 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
This should help.......
http://personal.utulsa.edu/~nathan-b...autotrans.html
Find out what tranny you have, if you don't already know. A google search on toyota tranmissions will tell you. Anyway, then look under the appropriate section.
Double check on that second code to see if you're reading it right. I wasn't aware there was a code 74 for these systems. Can't find it on the web, either.
Old 08-06-2010, 08:07 PM
95runner67's Avatar
Alright thanks for the link and I checked the list of trouble codes and it seems to be code 71 not 74.
Old 08-06-2010, 08:25 PM
thook's Avatar
Ah, that would be EGR system malfunction, for sure. Try reading this thread.......ignoring the offtopic BS, if you will. There's other info I can send your way, but this is a good start, I believe.
https://www.yotatech.com/forums/f116...-lines-140356/
chuckross1957
06-28-2019 10:19 PM
crammit442
7
11-29-2017 12:30 PM
4x4-runner
08-30-2015 08:55 AM
4x4-runner
08-02-2015 09:24 AM
mengquis
07-13-2015 10:39 AM
Quick Reply: Solenoid Location on transmission
