YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-23-2008, 05:15 PM   #1 (permalink)
sts2usnss's Avatar
Send a message via Yahoo to sts2usnss
Smell of gas with no sign of leak...
I have a 90 runner with the 3VZE. Driving home from work today I kept smelling gas. When I got home I walked all around it and could see no signs of a leak, however when I popped the hood you could tell it was coming from under there. I looked all over that engine and could not find any sigh of a leak. The smell does seem to be stronger on the passenger side though. I did the search on here and found some similar issues but they seemed to have obvious signs of a leak (actual gas dripping). Any ideas where to start looking?
__________________
1990 4Runner, 31X10.50 Treadwright MTG's, Flowmaster exhaust, Skyjacker Nitro shocks, K&N filter, Weston push bar.
I got your Jeep thing...Now it hurts when I pee.
sts2usnss is offline
Sponsored Links
To remove this ad, register today!
Old 07-23-2008, 05:50 PM   #2 (permalink)
olharleyman's Avatar
I just had to do injector seals for the same reason could not see it but smelled it realbad even brought my eyes to watering. Changed all the seals in the injectors no more gas smell and running better.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift Kit custom 6" coils rear
lock right #1620 Rear
Aussie Locker #xd-27527 front
5.29's Front And Rear
35 x 12.5 x 15 B.F.Goodrich KO's Micky Thompson Classic II Wheels
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
"Three People Can Keep A Secret If Two Peolpe Are Dead"
Benjamin Franklin
olharleyman is offline
Old 07-23-2008, 05:56 PM   #3 (permalink)
904_runner's Avatar
There is a fuel pulsation dampner on the end of the fuel rail underneath the intake plenum on the passenger side. Idk about yours but there is a little screw under the cap and it fell out of mine and caused it to catch on fire. Might want to check that.
__________________
-Mike
1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket
Soon to come: New wheels and tires, Sliders, CB.
One Day: 3.4 swap!
www.myspace.com/222948743
904_runner is online now
Old 07-23-2008, 06:34 PM   #4 (permalink)
sts2usnss's Avatar
Is there anyway to check the injector seals without removing them?
__________________
Old 07-23-2008, 07:53 PM   #5 (permalink)
sts2usnss's Avatar
anyone?
__________________
Old 07-24-2008, 12:23 PM   #6 (permalink)
I've heard about leaky fuel dampners being the cause for such a smell.
I'm having the same issue with my '88 3vze and I believe it is either the dampner--I'm not a mechanic, anybody got a pic or diagram or where the dampner is--or the fuel injectors are not installed correctly or are leaking.
I'm curious to know what is involved with fixing injectors seals too, or the dampner possibility.
Waiting for yota gurus/yodas to reply.
88runnertx is offline
Old 07-24-2008, 12:30 PM   #7 (permalink)
904_runner's Avatar
right around here for that fuel pulsation dampner
Need anything else just ask.
__________________
-Mike
One Day: 3.4 swap!
Old 07-24-2008, 12:47 PM   #8 (permalink)
mike92runnerSR5's Avatar
x3 on the pulsation dampner...had same smell...that was the cause..
mike92runnerSR5 is offline
Old 07-24-2008, 12:57 PM   #9 (permalink)
904_runner's Avatar
Oh to answer your question, it depends on what is wrong. No clue about the injectors, but for the dampener, the only two things i can think of is that it might be leaking from around the rim, or the screw fell out. If its the lip you will have to buy a new one. I personally just put red locktight on the screw and put it back in cause that was the problem with mine. Either way, it looks like you are pulling off the plenum and looking around.
Make sure you take care of it before it catches on fire, you don't want this happening!
GOod luck!
__________________
-Mike
One Day: 3.4 swap!
Old 07-24-2008, 01:11 PM   #10 (permalink)
abecedarian's Avatar
Location: In the air, on the ground- hopefully makin your cellphone work better.
maybe also make sure the hoses to the charcoal canister are in place and good condition.
__________________
Knowledge is that thing people don't have that they hope others do so they can get out of trouble without having to learn anything themselves...
It's time to re-claim 'green' as the color we deserve. Vote me as President, write-in candidate 2008.
Quote:
Originally Posted by stormin94 View Post
You've got my vote for president
While you're at it, write-out EVERY Senator and Representative you can.
join Yotatech chat at http://www.yotatech.com/misc.php?do=flashchat
abecedarian is offline
Old 07-24-2008, 05:53 PM   #11 (permalink)
sts2usnss's Avatar
Thanks guys. That definately gives me a place to start checking.
__________________
Old 07-24-2008, 06:08 PM   #12 (permalink)
Alex 400's Avatar
Quote:
mine was also fuel dampner. i got away with it. i was close to having a fire. check it with an inspection mirror. find it with the mirror and then if you can have someone start it and then turn it off and you should be able to see it coming out of the cap. thats what happened to mine. good luck and be safe.
p.s. if you need a new one, get a toyota one, don't get an off brand. I tried that but the only one they had was a hack job and had crappy threads. good luck.
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6 3vze, 5-speed, 31/10.50-15 toyo A/T, All Pro 1.5" coil springs, bilstein front shocks, doetsch tech mv12's rears, , MC heavy duty clutch
feasable wish list:
32-11.50R ssr
4.88's
ARB air locker
Probably-not-going-to-happen wish list:
JD fab 4wd long travel kit.
other ride:2001 Honda XR400R
Alex 400 is offline
Old 07-24-2008, 06:54 PM   #13 (permalink)
904_runner's Avatar
Maybe there should be a recall since this seems common!
__________________
-Mike
One Day: 3.4 swap!
Old 07-24-2008, 09:41 PM   #14 (permalink)
Alex 400's Avatar
Quote:
you would think so, wouldn't you?
especially something that can cause a fuel fire. mine was dripping on my crossover exhaust pipe. so i could see smoke. that's how close mine was......to
__________________
feasable wish list:
32-11.50R ssr
4.88's
ARB air locker
Alex 400 is offline
Old 07-24-2008, 10:03 PM   #15 (permalink)
904_runner's Avatar
See my above pics! Thats what caused that so You got lucky!
It was soo depressing for me, 16yrs old, first vehicle, catches on fire on the way home before i even got to drive it .
Luckly, my grandfather was a mechanic so we ended up fixing it in the driveway with the help from the family! Only good outcome is i know a bit about the engine now!
Now its just a braging thing! "250,000 miles, 3.slow, original headgaskets, been through a fire, you know its a toyota thing, lets see your "insert brand of vehicle here" do that!"
__________________
-Mike
One Day: 3.4 swap!
Old 07-25-2008, 04:14 AM   #16 (permalink)
Gavy's Avatar
I don't know about the 3vze but just last week on my 22RE I had to replace the fuel sending unit located on top of the fuel tank because of a leak however I noticed the gas smell 3-4 days straight before the leak opened up enough to actually let the fuel drip on the ground try and see if the smell is stronger back near the gas tank area
__________________
1994 DX 4x4 X-Tra cab 55K original miles
Eclipse Cd player
Infinity Reference speakers
Painted grill Black
K & N FIPK
Mobil 1 Mobileclean 5000- Purolator Filter
Gavy is offline
Old 07-26-2008, 08:24 AM   #17 (permalink)
sts2usnss's Avatar
Can't smell a thing towards the back of the truck. It is definitely coming from under the hood. The smell is strongest on the passenger side.
Again, thanks for all the tips guys. Hopefully I can find this thing soon. I bought a fire extinguisher yesterday...just in case!
__________________
Old 07-26-2008, 11:24 AM   #18 (permalink)
Alex 400's Avatar
yeah that is the side the fuel dampner is on too. i bet that's it. yeah have that fire extinguisher ready.
__________________
feasable wish list:
32-11.50R ssr
4.88's
ARB air locker
Alex 400 is offline
Old 07-27-2008, 05:49 AM   #19 (permalink)
sts2usnss's Avatar
From what I can tell this is where it is coming from. Plan is to clean it all up today and let it run for a while and see for sure. But when I run my finger across it, there is more gas than oil. Anybody know what this is? It looks like it's just a fitting?
__________________
Old 07-27-2008, 07:36 AM   #20 (permalink)
sts2usnss's Avatar
Woohoo! Gunk degreaser was on sale for $1.67 a can! So I stocked up. Now I have everything nice and shiny under the hood. Once it dries I'll go out and crank it and let it run for a while and see if I can actually find this leak.
Again, any help with letting me know what the above pic is would be great. I think it's just a fitting but then I'm an electronics guy. Under no circumstance do I consider myself mechanically inclined..lol.
__________________
Old 07-27-2008, 08:09 AM   #21 (permalink)
looks like a bracket to support maybe a fuel line?
__________________
Digg this Post!
